Torque wrench
  • s2driveruk
    • 12696
    Torque wrench
    Hi, does anyone have a big torque wrench i could borrow to do the cambelt?
    1992 3b S2 Coupe
  • s2driveruk
    • 12696
    Bump...anyone? Happy to pay for postage naturally
    1992 3b S2 Coupe
      • Dec 2017
      • 5992
      Is there an agricultural engineer anywhere near you? That's where I borrowed mine from and cost a pack of beer
        • Dec 2017
        • 5992
        This one just makes it if you are still struggling. It just short of the recommended torque or you could do 200nm plus 180 degrees. I have two of the smaller Teng wrenches and they are nice.
        https://www.screwfix.com/p/teng-tool...3-4-x-33/58074
        I was thinking of getting one of these. If you can't borrow one I might be interested it buying it from you after you have used it
        • s2driveruk
          • 12696
          Yeah i was looking at this then was looking at a norbar too...
          1992 3b S2 Coupe
            You only need a bit of maths and common sense. My 70kg weight on the end of a 600mm breaker bar ~ 400nm
            F=MA
            70 x 9.81 = 686n
            x 0.60m = 412nm
            Incidentally I’d say 200 + 180deg is a lot more than 400nm on this bolt.
            • SteveH
              • 4460
              I've always used the 200Nm + 180 degrees, but have never managed to get the full 180 degrees even with a long length of scaffold bar. You can get 200Nm + 90 degrees and then it gets very tight. I've never had one work loose with this method and replace the bolt each time. You will require a 3/4" socket and breaker bar. 1/2" will shear easily doing this bolt up.
              91 Modded 3B
              14 A6 Avant Black Edition
              • dhali7376
                • Nov 2009
                • 301
                Why not get a number of people together to chip in and buy it ? And then just use it when you need it amongst themselves? Obviously you will need to pay postage whenever the next person wants to use it ? I'd be happy to contribute. I know on other forums where a guy rents out specialist tools with a full holding deposit.
                  I’ve only ever seen these schemes end in tears
                  • Monkeymagic
                    • Mar 2012
                    • 3419
                    Alex you only weigh 70kg.. You jammy got.. Ha..
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      Personally I've got a 1inch breaker and matching 27mm socket. I got 200nm on easily and could not get 180 degrees on.
                      My car was moving on the axle stands.. Never had one work loose..
                      • Monkeymagic
                        • Mar 2012
                        • 3419
                        I also undo them with my milwaukee impact. Zings them straight out no issue.
                        • Fat Audi 80
                          • 10547
                          This
                          I only managed 90 degrees after the 200nm (I weigh 70kg too) and it was ****ing tight. No need for any more IMO
                          David, I have a 27mm socket and 3/4 inch breaker bar if you want to borrow them...
                          The Perfectionist
                          • s2driveruk
                            • 12696
                            Thanks folks...i am north of 70kgs so thats not the issue I remember just how much of a non event it was getting the desired torque with the right tool and wanted to achieve it that way again.
                            1992 3b S2 Coupe
                              I got myself a very large breaker bar too for this job
