WTD: 044 Fuel pump with coupe fitting kit
  • Colesy
    • Feb 2009
    • 2981
    Being lazy really. But thought I'd ask as you never know. If anyone has all the parts needed to fit an 044 into a coupe and a pump for sale please let me know.
  • Sonic
    • Jul 2006
    • 5514
    To fit the pump with replacement parts you'll want:
    895 201 779 H - Reservoir upper part
    895 201 531 A - Strainer
    N 903 307 01 - Adapter (Banjo)
    N 013 812 8 - Sealing Washers (x2)
    N 011 069 1 - Domed captive nut
    Should cost ~£100 all in, then you just need the fuel pump.
    S2Forum.com Administrator
    • Colesy
      • Feb 2009
      • 2981
      Thanks for the part list. Do you need all the parts you listed there or is there a way to fit it by modifying some of the original parts?
      • HPmuirt
        S2Forum April Fool
        • Apr 2005
        • 3014
        The only part that you can re-use is the basket (reservoir and strainer) but I would not recommend that route unless you can tollerate the car being out of action for a day or two.
        This is because you have you cut the inner part down to fit the larger Bosch pump low enough and the original basket will be old and brittle and could easily break, meaning you still end up buying new but having to wait another day.
        Much easier to build up the new pump, in the new basket with the banjo etc and then all you have to do when swapping things over is change the size of one of the spade terminals on the loom (Bosch studs are thiker than OEM).
        That also leaves you with a complete working pump as a back-up should the Bosch unit fail (however unlikely).
        Cheers n
        Si
        Subtle mods here and there
        2011 A5 3.0 TDi - Lava Grey
        • varia
          • 821
          • Current: United States
          If i got it right, he wants to fit an 044 fuel pump into a coupe.
          Then you told him the shopping list.
          But isnt the 895 201 779 H a coupe part, originally?
          • Colesy
            • Feb 2009
            • 2981
            From what I've read it was a part on early coupes (not sure whether all or any 3Bs have it though) on ABYs they use a different basket for a smaller diameter fuel pump.
            • Sonic
              • Jul 2006
              • 5514
              The parts listed above are what i used when fitting an 044 pump to my 1995 ABY coupe.
              • HPmuirt
                S2Forum April Fool
                • Apr 2005
                • 3014
                Yup, me too
                Cheers n
                Si
                • Colesy
                  • Feb 2009
                  • 2981
                  Does anyone have the full kit lying around? There has to be one somewhere!!
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    How much power do you need? I would consider the cheaper alternative of the 005 pump then you could also have money for the mounting things. The 005 pump also fits better then the 044.
                    Sleeper S2 Avant +450
                    A6 Avant 2.7t Stage 3
                    Audi S2 Coupe RS2'ed
                    • blackS2
                      • Apr 2010
                      • 455
                      I used the same parts - reservoir and strainer are from Audi 200 TQ20V also...
                      I currentlly sell my BOSCH 044 Pump with appr. 9000 miles on it...
                      ...I removed the 044 to put in a Bosch 413 a few days ago...
                      image:
                      but I sell the pump without additional parts!!! I still need them for the 413
                      price 120 EUR + shipping
                      pn
                      [__]=oooo=[__]
