0.86 Turbine housing : 571hp with 1.06 housing
    What size hotside?
    • Been
      • Aug 2010
      • 76
      .82
      '93 S4: GT35R 2.0bar 572hp
      • Been
        • Aug 2010
        • 76
        Small update: 2nd fuel pump installed.
        Hopefully we can get the GT35R at 2.5 bar
        • blackS2
          • Apr 2010
          • 455
          2,5 bar ? but not at rpm redline!?
          [__]=oooo=[__]
          • Been
            • Aug 2010
            • 76
            We will see...the engine is kinda "rev happy" with the scat cams...
            The only problem when tuning the car was the lack of fuel at 2 bar @572 ps.
            • blackS2
              • Apr 2010
              • 455
              ok, thats interesting ... we got some trouble with EGT above 1,8 bar at redline...
              ...(GT35 0.82) :-( 7a cams
              ...so the curve was 2,3 to 1.8 at redline ... 2 bar up to 6500... compression 8:1...
              Scat cams... you mean cat cams... what number?
              [__]=oooo=[__]
              • Been
                • Aug 2010
                • 76
                Yes Catcams, we use scat rods
                Will check the cam nr. for you...i remember we had the slightly adjust the head (clearance for the high lift), allthough the catcam site said: "direct drop in, no adjustments"...
                • Been
                  • Aug 2010
                  • 76
                  BlackS2,
                  Catcams: 1002303
                  • robo
                    • Aug 2004
                    • 2086
                    • Home: Poland Current: England
                    #54
                    BlackS2,
                    Catcams: 1002303
                    With these cams did you have to remove some material from the cam cover in order to get them turning 360 deg?
                    sigpic_________
                    Rob
                    • prj
                      • Mar 2010
                      • 6308
                      Let me guess, there was no relay on fuel pump?
                      • repo
                        • Dec 2004
                        • 893
                        Your pump feed is two sizes too small.
                        Also i doubt 35r can hold 2.5bar for long with cams that have so much lift you need to mill the head and the valve cover.
                        • Billman
                          • 4129
                          #57
                          How high was the EGT above 1.8 bar at the redline?
                          Go Holset or Go RS4
                          • Audi_CQ
                            • 940
                            • Country: Norway
                            #58
                            Have been running with the same cams (before swithcing to mech cams) and no milling was required.
                            • blackS2
                              • Apr 2010
                              • 455
                              sometimes 1000°C on "Autobahn" (5 Gear)
                              [__]=oooo=[__]
                              • prj
                                • Mar 2010
                                • 6308
                                Interesting, I have no problems with EGT even with GT30R and 1.9 bar to 7000...
                                What kind of exhaust manifold/exhaust?
                                What timing do you have at redline? Can you run more?
