Hacking the Motronic ECU (Audi RS2)
  • Dybro
    • May 2008
    • 69
    • Country: Denmark
    #106
    Originally posted by prj
    Sure. I even had to rewrite some bits of it...
    For you, perhaps yes, since you lack the necessary skills. 8051 instruction set is tiny though...
    That said, you don't need to disassemble anything to tune.
    What are you trying to do?
    OK. assume this is good news...
    Maybe my plans are to extreme for a beginner. But anyway - here they are:
    create multiple fuel- and ignition settings so that I can run it like a multifuel engine (gasoline ethanol, different blends of it. maybe also LPG/Autogas in the future).
    Maybe I will use an ethanol-content-sensor(not sure yet - I could also choose to have a rotary switch to change map manually) actually 4 or 5 fuel- and ignition-settings + 4 or 5 cold start settings would be enough (15 in total)
    a switch to select an other maf-sensor.
    a switch to change the injector-constant-value
    improve the throttle response(really think it's "lazy", and it is already chip-tuned)
    Anti-lag system if possible
    I also want to have motronic converted to wide-band-lambda if possible.
    Can the trigger-logic in M2.3.2 be converted to 60-2 + cam-sync ? would be very nice in case of a flywheel configuration changes
    If all this is to difficult and time consuming(sure it is time consuming) I might want to go for an after-market ecu. But not many after-market ecu's will support the 135-audi-trigger, and this is why I like the old Bosch.
    1993 AAN UrS4 Sedan
    • Jonas_R
      • 3781
      • Country: Denmark
      #107
      If you want all that you could just go with VEMS.
      Sleeper S2 Avant +450
      A6 Avant 2.7t Stage 3
      Audi S2 Coupe RS2'ed
      • prj
        • Mar 2010
        • 6308
        LPG/Autogas always has a separate ECU, which goes between the stock ECU and the injector outputs.
        For Ethanol/Gasoline, it is possible to make a hardware switch.
        Useless. One good setting is all that is needed.
        Useless, you will not fit different MAF's depending on your mood. Also, it took me two months to make a SW for a different MAF sensor.
        Useless, if you change injectors, you remap. Or if it's E85/Gasoline setting, you just change setting via hardware switch.
        Boost is based on TPS value. And it is good that way, because it saves the turbo from unneeded stress.
        If you want full boost, just press your foot down. There is a reason why the throttle isn't "on/off".
        Not possible.
        Not possible. Use a wideband controller that has narrowband output. MAF is precise enough. Motronic does not need to run closed loop all the time.
        Not possible.
        Buy an aftermarket ECU.
        • Dybro
          • May 2008
          • 69
          • Country: Denmark
          #109
          Ok thank's.. then I will properly choose an after market ecu.. I have been playing around with the VEMS software, and unfortunately I don't like it.. I think all the settings are confusing(especially the triggering settings) Also I think that the map-switching possibilities don't satisfy my needs(I managed to find 2 settings only, a year ago I think). I would like 3 or 4 different settings.....
          But I have found an ecu that should do all this. It is the adaptronic 1280s - 12 inj. 8 ign. and has almost all the fancy extra ecu functions plus PLC-like logic for custom functions. I really like the PLC-logic style.
          Some people in a tuning shop in Holland is actually preparing the 1280 for common rail diesel. That's pretty cool IMO.
          If some of you would like to check out the adaptronic 1280 software you can get it here http://adaptronic.com.au/files/e1280...3000_Setup.exe
          Daw Jonas. Som du nok kan se, så er jeg ikke umiddelbart så begejstret for VEMS'en. Men da der er lavvande i kassen fordi jeg studerer, så kunne jeg måske godt fristes alligevel. Kan du hjælpe med opsætning af trigger + diverse på en standard AAN??? tror du det er nemt at sælge vems'en om 3-5 år(55-pin typen)?
          På forhånd tak
          1993 AAN UrS4 Sedan
          • A80Avant
            • 10873
            • Country: Greece
            #110
            why are you putting the turbo on uneccesary stress if you are asking for more boost on part throttle?
            • Dan
              • Jun 2008
              • 1242
              I guess the argument would be that you're demanding more airflow, by asking for more boost, but then restricting that airflow with the throttle (increasing backpressure).
              1993 ABY Coupe | BMW R1200 GS
              A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
              • prj
                • Mar 2010
                • 6308
                Yep, pretty much.
                You basically let the turbo spin hard all the time, building boost and then you strangle that boost (airflow) using the throttle plate.
                That is why in proper electronic boost control the target boost table is a 3D table with throttle position taken into account.
                This makes throttle response more adjustable and reduces unnecessary stress on the turbo, when you just want to accelerate slightly. Plus there is less backpressure during non-WOT operating conditions, which exceed spring boost, as the wastegate is open.
                With our old external wastegates this is more limited, but with the newer internal ones, you can have a much wider modulation of boost pressure, thus further extending the life of the turbo.
                • A80Avant
                  • 10873
                  • Country: Greece
                  #113
                  well, that is true in one sence, but when you have the external wastegate and a stiff spring, you are trying to allow a big turbo to build up boost as fast as mechanically possible and therefore one of the ways to do that is to be able to allow for a fast TPS response as well.
                  On VEMS you have 2 separate tables, one for TPS vs Boost and one for the boost curve itself(simplest way to control boost), otherwise you can still have a 3d map of boost vs rpm as well.
                  I usually ask for 90% of rpm calculated boost when throttle is above 50% pressed, because on simple overtakes on low revs where the turbo is not kicking in due to lag, i want to be able to have a fast responce without having to go WOT all the time. Therefore on low revs, the turbo along with the N75valve is basicaly trying to keep the wastegate shut so that the turbo can build up the pressure fast. I dont think this is causing any more stress to the turbo itself. I understand that keeping 50% TPS and asking for 2bar of boost is more stresfull, but usually when the turbo is in the rpm range that it can give me that boost i do use WOT.
                  For me i think that having a more responsive TPSvsBoost allows for a more subjective and driver specific driving habit, and i do like it.On smaller turbos which spool faster it indeed may pose a bit more stress to it, it will surge more often, but i dont believe that it will extremelly alter the turbo's life
                  • Dybro
                    • May 2008
                    • 69
                    • Country: Denmark
                    #114
                    by improving the throttle-response I mean tuning the tps-based transient fueling and not incising boost at part-throttle
                    1993 AAN UrS4 Sedan
                    • prj
                      • Mar 2010
                      • 6308
                      It is not "fast TPS response". It just kills any throttle modulation.
                      And your logic is very wrong. The bigger the hotside, the softer the wastegate spring needs to be.
                      The required strength of the wastegate spring is inversionally proportional to hotside size (proportional to backpressure).
                      Thus, a smaller turbo, with a smaller hotside requires a stiffer spring to drive to high boost levels, than to drive a turbo with a larger hotside to the same boost level.
                      Boost vs RPM is needed, because compressor maps are not flat. By having a boost vs RPM table you are able to make more torque/hp.
                      And what for is your throttle pedal? Just make the pedal travel shorter.
                      I am sure you would like a device like "sprint booster" if your car had an electronic throttle pedal. Going WOT is perfectly fine and then slightly letting off when too much boost starts to build. Not to mention, that you will get faster spool/more power this way, then trying to spool when the intake is strangled by the throttle.
                      And increase the backpressure, and stress the turbo more than needed and reduce fuel economy. But I guess none of those things are important to you.
                      You are just wrong on this one.
                      If you use a stiff spring, you are already severely reducing the turbo's life. If you use a stiff spring and basically flat TPS mapping, you are doing it even more.
                      Remember, the TPS mapping comes into play when boost pressure exceeds spring pressure only.
                      • prj
                        • Mar 2010
                        • 6308
                        Transient fueling is very good on stock.
                        Fueling is not power. Spark is power, and fueling is only a tool to combat detonation.
                        This is really basics. Pick up a book.
                        • Dybro
                          • May 2008
                          • 69
                          • Country: Denmark
                          #117
                          Fueling is not power. Spark is power.
                          Proper ign. timing is power - year sure.
                          Transient fueling is very good on stock - not in my AAN. Mostly it get to little fuel (a 1/3 second delay) if I step on it fast during idle or fast idle...
                          1993 AAN UrS4 Sedan
                          • prj
                            • Mar 2010
                            • 6308
                            lol... idle...
                            And you have a datalogger with at least 1/3 second resolution as well? I would really like to see a log.
                            During *transients* fuel delivery is perfectly fine. There are no lean spikes.
                            • Dybro
                              • May 2008
                              • 69
                              • Country: Denmark
                              #119
                              lol... idle...
                              Well.. it feels something like a 1/3 second. that's why I think the throttle-response is lazy. If I run it on E10 or E15 mix it get worse witch make me think that transient-fuel is to lean - even for pure gasoline..... (I don't have a wide-band probe yet)
                              But it has an unknown chip in it. Maybe the tuner didn't do his job properly.
                              1993 AAN UrS4 Sedan
                                So actually its not stock..
