Has anybody ever found a source for a small PCB that accommodates these 3bar MAP sensors - with a 3-pin header/connector that can easily be soldered onto ECU board ?
I always hated soldering the wee blighters inside the ECU and my eyesight is only getting worse these days. Would be an easy project for someone with PCB s/w and means to make small batch...
