MPXH6300 PCB Question
  • MPXH6300 PCB Question
    Has anybody ever found a source for a small PCB that accommodates these 3bar MAP sensors - with a 3-pin header/connector that can easily be soldered onto ECU board ?
    I always hated soldering the wee blighters inside the ECU and my eyesight is only getting worse these days. Would be an easy project for someone with PCB s/w and means to make small batch...
    Last edited by S2central.net; 4 January 2018, 18:00. Reason: JPG added (hopefully)
    I know a fella up the road from you that has PCB prototype kit, Inc a wee CNC mill for pcbs.
    Sent from my Moto G (5) using Tapatalk
      That man Ivan ???
        Nope Ian. Will text you a number.
          Ah pm me your number I have managed to loose yours...
            Just design a board using any CAD software... The only thing that is a bit tricky is the 2.54mm spacing double angled connector. Not sure if it exists.
            Could try to find a 3-row right angled ribbon and a normal right angled connector, then combine the two, should be quite sturdy i'd imagine.
              There are plenty PCB vendors online for making one according to your design. Or just take some prototype PCB bord and place it on there.
              1967 fiat 500 future project
              1976 audi 100 coupe S
              1989 vw corrado 16V
              1989 audi 90 quattro 20V sport
              1994 audi RS2 project
              1994 audi RS2 parts car
              1995 audi RS2 project
                Yeah I was looking at software such as "circuit wizard" or similar.
                  Diptrace, eaglecad.
                    I have here some this PCB´s done myself.
                    This gallery has 1 photos.
                    .: Audi Coupe Quattro 20V 91' :.
                    .: Audi/PorscheRS2 95' :.
                    .: Mitsubishi 3000GT VR-4 96' :.
                      God I love this place !
                      @Nuno - can I pls buy a handful of these bare PCBs from you ?
                        Hello,
                        How much you need?
                        Actually i have 6 in stock.
                        Later i can do more PCB´s.
