Aftermarket management for 5 cylinders
  • Aftermarket management for 5 cylinders
    What makes are out there to work with the 5 cylinder engine?
    Audi A6 AEL 5cyl Quattro breaking.
    Audi A5 3.0tdi Quattro Stage 2
    07947385043
    If you mean programmable ECU, this subject has been talked many times earlyer, but here is short list:
    Hestec
    Haltech
    Autronic
    Megasquirt
    Tatech
    Motec
    AEM
    Vems
    and the list goes on.
      Thanks all i needed cheers for the heads up!
      07947385043
        Hestec
        Haltech
        Autronic
        Megasquirt
        Tatech
        Motec
        AEM
        Vems
        Emerald and DTA should be on that list, Megasquirt should not!
          034 IIc
            Pectel
            Audi 90 quattro (Typ 85)
            20v turbo conversion
              KMS should also be on the list (actually stands for Kronenburg Management System, and no, it is not a joke...!!!!
              Chris
                Originally posted by jogi730 View Post
                Pectel
                I agree superb management
                  why is megasquirt frowned upon? It seems to have all the features of any other ecu?
                  Is there a viable technical reason?
                  Volcano ABY coupe
                  Ant
                    Did not mean to diss those products, just did not membered all at once.
                    No shortage of these nowadays
                    ps. this is second try first got "db error"
                      Megasquirt i believe is one of the cheapest of its type,some have had great success and others havent.Seen a few turbo'd beetles running it very effectively.
                      There is also microtech.
                        Why should megasquirt not be on the list ??? Have you had any experience with it ??
                        I have had experience of DTA and Megasquirt V1 and V2 but IMHO I would use one of 034's range of ecus simply because they are aimed at the Audi interms of plug n play loom etc.
                          034 IIc (megasquirt) should be on the list
                            Yes I had it in my old car, pile of sh*t. Ditched it and had emerald installed
                            Now there's a proper ECU
                            • #15
                              Obviously knew what you where doing then
