Aftermarket management for 5 cylinders
Peter Nanassy
Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
http://www.carstyling.hu/car_shower.php?id=19845
http://www.youtube.com/watch?v=FYOVA_285Rs
http://www.pectel.co.uk/sub_page.cfm...ucts/editID/35
http://www.pectel.co.uk/sub_page.cfm...ucts/editID/15
This is very good if perhaps somewhat overcomplicated. The main problem is finding people who can program any ECU. Ahmed Bayjoo definitely knows his stuff, but as he is so busy is a nightmare to get hold of. He has developed and enhanced the programming software. I think Wayne at chip Wizards can also work with Pectel (don't know how good he is though), but other than that I do not know of anyone else - perhaps someone else does?
ChrisLast edited by jogi730; 18 July 2007, 21:41.Audi 90 quattro (Typ 85)
20v turbo conversion
Originally posted by gnutz2 View PostI emailed dave walker a couple of months ago because i wanted to use the emerald ECU`s.
He replied.
Hi Baz
The five cylinder version of the K3 is still under development. No traction control as yet either.
Dave Walker.
I think im going for DTA then.
I don't see knock sensor support on the K3 either - I'd see that as much more important than traction control - we have quattro for that
PaulPaul Nugent
Last time i checked even Motec didn't have inputs for knock sensors, so the cheaper stuff really wont.
Megasquirt guys were looking at it thiough.Carlos.
A good compromise would be a knock-sensor device that could be used for mapping - give visual indication of knock intensity under load... Even if the ECU couldn't adjust timing from the inputs. There is a useful looking knock detection circuit at Megaquirt that I looked into - actually someone here offered to build it. Must dig that thread up.
PAulPaul Nugent
DOOOOOOOOOOH Me. Just back from Spain working, will be visiting Maplins at the weekend then.Carlos.
Originally posted by S2central.net View Post**** - all that excitement for nothing maybe - I only see reference to a maximum of two coil packs... And it doesn't seem to support five sequentila injectors in the way I'd expect - maybe the 5th can be done as an auxiliary output. Dammit...
I assume that Jamo's old car that got the Emerald treatment was a 3B (single coil) and the injectors were 'batch fired' instead of sequential.
Sigh............
VEMS has 2 Knock sensor capability, plug n play Motronic Harness ect.Last edited by Billman; 19 July 2007, 13:23.Go Holset or Go RS4
I will look into VEMS, but I have just emailed 'the man' at Emerald and reminded him of the rampant market opportunity across the I5 fraternity of Audi and Volvo owners...
Hopefully will hear something back soon.Paul Nugent
That VEMS stuff has a lot going for it at least from a hardware integration POV with up to eight invidually controllable coils and injectors plus the integral MAP is nice along with knock support. They have obviously done an I5 Audi or two as well...
WOnder what its like to program ?
PaulPaul Nugent
Sorry Jamo - had the page open to long - was out in the sunshine there for a moment - missed your post. Programming is my main concern unless its a really user-friendly system.
PaulPaul Nugent
Well,i was one of the first ones who installed successfully VEMS into a 5cyl Audi.Since then i made 4 20VTs and a 10VT is currently under construction.Having direct contact to the developer we managed pretty good results (11.19@206 with stock cylhead),including 5 coil support,and our individual trigger type.There are still some major problems with the system,but for that price you simply cannot find any better.
And it uses a modded MegaTune software.
About the "Auditrigger" (Stock audi 20VT trigger support) i cant say much,since i spent 3 days firin up the engine without sussecc back in 2006,i stopped messing with it.
VEMS also has now a Plug and Play solution for AAN engines,and i think for the ABY too.
PeterPeter Nanassy
