Looks like i am going to go with VEMS ECU engine management.
Email i recieved
We have a unit with the Motronic plug, so its a case of removing your old ECU andplugging the VEMS unit in. Then routing the wideband's subloom, and a tube for the MAP sensor.
We're currently 'blessed' with using MegaTune, which is simple enough to use, theare as that make tuning easier is the fact that VEMS has a built-in widebandcontroller, so you get live updates on the AFR as you are mapping, and thewideband feedback will keep the fuel in trim. If you choose the EGT option, you get even more information regarding the timing and temperatures under boost.
We use a speed density system, so you can remove the airflow meter. Speed density is much better for mapping against boost.
we can supply a base map, obviously it wont be perfect as the characteristics of your modified engine will be different to a stock one.
Motronic VEMS with built-in 400kpa (3bar) MAP sensor costs £598.30
Bosch LSU4 Wideband sensor £53.83
The EGT option is around £20 and the fast 6mm EGT sensor including plugs and1/8bsp is £52.53
We have excellent boost control, optional anti-lag, launch control and shift cutwhich is included in the price.
What you guys think?
Craig
Email i recieved
Craig
