What is needed to run with VEMS?
  • a4kquattro
    • Feb 2005
    • 411
    Originally posted by Jamo
    I believe you found a way to install the 1.8t sensor in the stock sensor position but I cant find the details on motorgeeks, could you post here please?
    Also where is actually the best position for the sensor?
    Hi Jamo,
    without drilling the hole larger, you need to grind down the diameter of the stock sensor, like so. Using a lathe to do this would be nice, but chucking it in would be difficult..
    Honestly, I'd just recommend drilling the hole larger in the manifold. it makes for a cleaner install.
    Marc Swanson
    Proprietor, EFI Express
    95.5 //S6 Avant
    90' Coupe Quattro V8 4.2L twin turbo
    93' //S4
    83' UrQ
    97' F250 7.3 diesel
    • a4kquattro
      • Feb 2005
      • 411
      and to be clear this is not "needed to run vems", just something to improve the IAT accuracy over the stock PTC sensor if so desired.
      Marc Swanson
      95.5 //S6 Avant
      93' //S4
      83' UrQ
      97' F250 7.3 diesel
      • Jonas_R
        • 3781
        • Country: Denmark
        #33
        Should there be any problem installing this sensor in the pipe just before the throttle body?
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • a4kquattro
          • Feb 2005
          • 411
          that will work "ok", in the manifold is better but part throttle and closed throttle IAT will not be as accurate.
          Marc Swanson
          95.5 //S6 Avant
          93' //S4
          83' UrQ
          97' F250 7.3 diesel
            sorry to hijack - will that intake temp sensor work with motronic?
            • a4kquattro
              • Feb 2005
              • 411
              no. The 1.8t sensor is NTC or "negative temperature coefficient". Stock AAN/ABY/etc air temp sensor is PTC or "positive temperature coefficient". Not compatible. VEMS can cope because it is possible to alter the hardware and update the calibration curve to fit whatever sensor you want to run..
              Marc Swanson
              95.5 //S6 Avant
              93' //S4
              83' UrQ
              97' F250 7.3 diesel
              • max_s2
                • Mar 2006
                • 498
                • Country: Latvia
                #37
                IMHO the easiest way is to cut resistor from the old "house" (stock 20vt PTC's one) and solidaire the 1.8T resistor (NTC one) in it. No drilling or plastic cutting or else what, just a nice solidaire and you're done
                • Bram
                  • Aug 2006
                  • 2582
                  What do I need to change in the VEMS hardware in order to make use of this new sensor?
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    #39
                    Marc:
                    What is the VR pin adaptor you mention on your site?
                      Marc:
                      When you run VEMS you have to swap the pins on the VR Plug.
                      Marc has an adapter to the plug so you don't have to do this.
                      However I heard this could be changed in the VEMS software without having to change the plug, I can't comment if this is true or not though
                      • GazzaG60
                        • 4133
                        this isn't done in software. the polarity change is needed. the good thing is motronic will still run with it changed if need be.
                        the other change was that the wiring for the vems PNP is for aan and not aby. its an ignition wire that can either be swapped or done in software.
                        the only change needed to run vems is the polarity. then you have the option of the temp sensor. i know that peter uses a different sensor again to that. must say ive seen no real issue with mine but it must be there. i believe its the poorer IC'd cars that suffer most.
                        • a4kquattro
                          • Feb 2005
                          • 411
                          there is a "piggybacked" resistor inside the ecu that needs to be removed. once the resistor is removed you need to re-upload your firmware with the appropriate temperature curve for the 1.8t sensor. I can help you with all that when you are ready.
                          Marc Swanson
                          95.5 //S6 Avant
                          93' //S4
                          83' UrQ
                          97' F250 7.3 diesel
                          • Jonas_R
                            • 3781
                            • Country: Denmark
                            #43
                            Marc: Can I buy that adaptor cable from you?
                            • a4kquattro
                              • Feb 2005
                              • 411
                              Sure, email me
                              Marc Swanson
                              95.5 //S6 Avant
                              93' //S4
                              83' UrQ
                              97' F250 7.3 diesel
                              • Bram
                                • Aug 2006
                                • 2582
                                The main problem for me is to drill a bigger hole in the IM, since it's attached already on the the cyl head. I can not find a way to make sure there are no left overs of the drilling metal on the inside of the IM, so it's a bit too risky for now.
                                How do you normally drill that bigger hole in the IM and what precautions should I take?
