jamo on vems there is a realtime display. use this to set pid. same as its used to set for idle. its in a menu on megatune. IIRC add 2% to the value shown in the box.
not sure if this helps or not. hard to explain
Cheers I'll have a look, I don't know megatune at all as I did all my messing in vemstune for the higher firmware
I need to play with idle as well, never ending list
Yeah thats the same method but I wouldn't buy a 4 port if you have 3 port solenoid already
You can use a 3 port in the same method to top and bottom without the boost tee, boost in to one valve and then it switches it to top and bottom
The only difference is the solenoid blocks boost on the line with no vent.
