Not really that much to tell. We hooked it up in dual port (the setup where it does not went to athmosphere) and he (my tuner) then had to tweak the boost map a bit. Think he had to turn it down a bit.
However we had a small problem of boost building up in the first couple of runs. So we switched to the setup where it wents to atmosphere doing gear changes.
However the build up of boost was due to the fact that the Eboost2 manual has an error where it labels the ports 1-3 wrong on the solenoid. I just discovered this recently.
