I have been reading for quite some time the advantage of using the TS solenoid valve (http://www.s2forum.com/forum/showthr...smart+solenoid), but wondered if adaptions need to be made to VEMS settings in order to get it work instead of the OE N75?
Jonas, did you have a go combining both VEMS and the TS solenoid?
And would the 40psi TS version be capable enough to control boost with a 1.9 bar WG spring say up to 2.0 bar turbo pressure on my new CT355?
And that's why I am so interested in using this new solenoid combined with VEMS, so they work together and would allow me to not pay for an expensive boost controller and use VEMS to it's maximum potential.
