eboost 2 and motronic?
  • s2_bo
    • Oct 2005
    • 6067
    Does any one have any experience with using the eboost 2 boost controller with the factory motronic ecu?
    Does it require a remap to use it effectively?
    Can it just be added in to the pipeline so to speak with good results?
    Would it beneficial on a rs2'd s2 3b?
    Cheers.
    Bo
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • GazzaG60
    • 4133
    fit it set boost and bobs yer uncle.
    it transformed my standard aby.
    it would be benificial on any car with a turbo IMO.
    i sit mine in a perrin racing pod on the column with a defi meter bf boost.
      Having tried a few springs in the WG on mine, the car didn't particularly like early boost and hiccuped a bit. I would suggest that as long as you keep the maximum close to whatever map you have and turn it down for economy then it'll be better. Perhaps a strong WG spring and remap would be an alternative, depends what you want from it.
      • Jonas_R
        • 3781
        • Country: Denmark
        I'm using it on my 3B rs2 setup and it works really well. I would ofcourse recommend that you have a AFR gauge as well just to check up on things.
        But really easy to use and setup.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • GazzaG60
          • 4133
          no need for a spring. thats a waste IMO. a remap would cost more too. for no real gain if you are after just better control of boost over the factory crap. issue is not usually the map its the n75 hardware
          1. disconnect factory solenoid.
          2. fir eboost solenoid. mines on inner wing.
          3. use the standard dual port setup so you are connected top and bottom.
          best to do a run with the controller set on the 00's first. this gives you the can boost. then tweak in some duty till you see desired (read boost fueling set for) boost. once this is done add some gate pressure to spool faster. using the controller in its basic form is still great.
          i set the standard aby to 1.1 bar. it read fine on AFR. it would spool in a fraction of the N75 and hold rock steady. a massive, massive improvement.
            t.
            No matter what boost control you have a sensible stiffer spring will improve boost response.
            For you Bo have you tried the solenoids you bought connected to both the upper and lower chamber?
            • GazzaG60
              • 4133
              if you get a well set controller thats not the case. the spring just means less solenoid duty and in the case of a poor setup that would equate to better control. top and bottom is pressure balance.
              what the spring does in the case of some controllers is allow you to have higher boost. can boost is 0 as far as the controller is concerned. some controllers work on a max above can pressure principle.
              • s2_bo
                • Oct 2005
                • 6067
                Cheers guys, im going to give it a try.
                No havent tried the ones i bought jamo, still need to replace the clutch first as atm its not allowing any boost because of slip.
                Ill post on here once its all done and im happy with it.
                May take a couple of months though realistically.
                91 S2 coupé - RIP
                • GazzaG60
                  • 4133
                  run the map sensor down to where the ecu is. then t-piece. saves breaching the firewall. boost gauge too.
