Controlling IC spray with VEMS?
  • Jonas_R
    • 3781
    • Country: Denmark
    Is it possible to control a Intercooler spray system with VEMS?
    What I would like to do, is activate a valve for a period of time, when the intake temperature goes past a specific point and also need to setup one more parameter related to either boost or RPM so I can control that it does not spray when I driving around in the city etc.
    /Jonas
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • a4kquattro
    • Feb 2005
    • 411
    /Jonas
    check under the "misc outputs" section. use one of the spare output channels wired into your SC6 connector. just remember most of those are low current, so use them to switch a relay.
    Marc Swanson
    Proprietor, EFI Express
    95.5 //S6 Avant
    90' Coupe Quattro V8 4.2L twin turbo
    93' //S4
    83' UrQ
    97' F250 7.3 diesel
    • Jonas_R
      • 3781
      • Country: Denmark
      Thanks Marc I will have a look.
      On another question, is it correct that you need to make a special request when ordering your VEMS box if you need to control the carbon canister valve?
      • a4kquattro
        • Feb 2005
        • 411
        yes.
        Marc Swanson
        95.5 //S6 Avant
        93' //S4
        83' UrQ
        97' F250 7.3 diesel
        • Jonas_R
          • 3781
          • Country: Denmark
          ****** , that kinda sucks
          • a4kquattro
            • Feb 2005
            • 411
            tis' why people order from dealers who have BTDT and know how to config the boxes. wink wink. nudge nudge
            Marc Swanson
            95.5 //S6 Avant
            93' //S4
            83' UrQ
            97' F250 7.3 diesel
            • Jonas_R
              • 3781
              • Country: Denmark
              Yeah oki I guess vems.hu has not BTDT then But I get your point.
              Guess I will have to use a wire and control it via the SSC6 connector instead.
