For those of you that installed the EGT, can you please post some pictures of your install?
EGT Install, pics please!
You can see the place of bung(for the probe) better in this pic. There is also a bung for ex-pressure.
Looks good guys! More pics pleaseLast edited by Lighthouse; 18 January 2011, 18:30.'10 A5 Coupè 2.0TFSI REVO
90 quattro
X- 91 S2 Coupè 467hp, 670nm!
I'll need to install mine as well.
Guessing post turbo is useless?
apparently safer as they say that if the EGT brakes, it wont damage your turbo, BUT you always need to add to the temperature some degC to get the actual figure, depending where you have fitted the sensor.
the higher the temp, the less you add.
Normal place if you have a stock DP is the hole provided, and yes deff safer as egt sensors ca sometimes drop off.
