EGT Install, pics please!
  • Lighthouse
    • Jul 2007
    • 229
    • Country: Norway
    For those of you that installed the EGT, can you please post some pictures of your install?
    '10 A5 Coupè 2.0TFSI REVO
    90 quattro
    X- 91 S2 Coupè 467hp, 670nm!
  • A80Avant
    • 10873
    • Country: Greece
    here is mine
    probe is at the EM collector
    • Thuppu
      • 4115
      You can see the place of bung(for the probe) better in this pic. There is also a bung for ex-pressure.
      • Lighthouse
        • Jul 2007
        • 229
        • Country: Norway
        Looks good guys! More pics please
        90 quattro
        • prj
          • Mar 2010
          • 6308
          I'll need to install mine as well.
          Guessing post turbo is useless?
          • A80Avant
            • 10873
            • Country: Greece
            apparently safer as they say that if the EGT brakes, it wont damage your turbo, BUT you always need to add to the temperature some degC to get the actual figure, depending where you have fitted the sensor.
            the higher the temp, the less you add.
              Normal place if you have a stock DP is the hole provided, and yes deff safer as egt sensors ca sometimes drop off.
