You are wrong here.
You assume that no boost is built, but there is. It is nothing like playing with the gas, because you are WOT and turbo is spooling up.
I get 0.7 bar boost just pushing down the pedal and holding it with the current implementation.
Your turbo is already spooled up and when you dump the clutch it instantly boosts, there is no bogging down whatsoever.
This is for stock turbo.
A larger turbo will not build as much boost, but as long as fuel cut rate can be adjusted, it's possible to build boost without dumping unburned fuel into the exhaust manifold.
I posted videos, here is a video of my car on dry tarmac. All I do is hold down the gas and dump the clutch. My 1.7 tonne UrS6 Avant easily spins it's wheels and keeps spinning:
on the last event 3wks ago we were 7th o/a out of 91 cars only 6 seconds from being 6th ,the 6 cars in front were 1 wrc subaru,1 wrc focus,1 evo 9, 2 darrian [kit cars700kg ],and a bloody 1400cc/190bhp nova[700kg]we were in beating , 15 cars in our class, but i went off on stage 3
sorry its off topic [just fying the audi flag]
