Launch control for Motronic
Any progress with this?
Well my UrS is still in bits.
I guess when you fly around Europe and tune others cars you don't have too much time for your own.
I have not really pursued this much further, because no one really needs ignition based antilag that much.
The only thing that I made is no-lift-shift with ignition cut, but it needs a button under the clutch.
Even with a GT35R and the current Launch control you get about 0.5 bar and it does not bog down and spools up instantly. And then you can proceed with the no-lift-shift.
So I think I got this covered pretty good as-is.
It is really a question of sitting down and writing some code - I know exactly how to do it, and I have tested a concept that worked. I just do not have much time :/Comment
