Launch control for Motronic
  • Thuppu
    • 4115
    Originally posted by prj
    When I get my UrS6 together again, then...
    Dmitri, how is the UrS? Any progress with the antilag?
    • djh
      • Jun 2011
      • 1622
      • Home: United States Current: United Kingdom
      #317
      I am mainly doing it "because I can"
      Btw, I am working on a properly configurable anti-lag system...
      Made 1.5 bar when stationary then I let off the throttle
      Any progress with this?
      • prj
        • Mar 2010
        • 6308
        Well my UrS is still in bits.
        I guess when you fly around Europe and tune others cars you don't have too much time for your own.
        I have not really pursued this much further, because no one really needs ignition based antilag that much.
        The only thing that I made is no-lift-shift with ignition cut, but it needs a button under the clutch.
        Even with a GT35R and the current Launch control you get about 0.5 bar and it does not bog down and spools up instantly. And then you can proceed with the no-lift-shift.
        So I think I got this covered pretty good as-is.
        It is really a question of sitting down and writing some code - I know exactly how to do it, and I have tested a concept that worked. I just do not have much time :/
        • Thuppu
          • 4115
          Thats fully understandable.
