Launch control for Motronic
Im more a traffic light launch not track so cant really video it, and probably not that good at that tbh but it provides entertainment in the mornings commute. But the rally method used to be rev it right up, dropping the revs then kicking it again as you drop the clutch.
I read the title and 1st page to no avail it seems, but LC has a different meaning entirely to AL in my thinking.Comment
And your car bogs down every time, especially with a bigger turbo
I hope this thread doesnt confuse people.
Variable launch control (VLC) is one thing - essentially a modification to rev limiter while car is stationary so the engine can build boost in preparation for an "exciting" departure.
Full blown antilag system (ALS) is something else whereby the ecu essentialy tricks the engine into sparking late when the driver has lifted off (for a gear change or corner). The result of that is lots of popping and banging that keeps the turbo spinning in order to minimise any lag when the throttle is reapplied. This is not really for casual / street use as it must surely increase stress on the turbo and is really only for race / rally application IMHO.Paul Nugent
All I can say is - please go to at least one drag race and see how big turbo cars launch.
Until then, please sell your S2 and buy a carburetted car, because obviously electronics are all driver aids, and electronically controlling the engine based on driver inputs is also a driver aid.
That is all that I am going to say on this subject.Comment
for true antilag most of the time there are also other hardware modifications necessary in order to let enough air past the TB so that the excess fuel can burn. There are kick solenoids and/or other mods for this that either hold the TB open during gearchanges or let enough air bypass the TB. with the stock hardware a full ALS is not doable.Go Holset or Go RS4Comment
Full ALS is not doable, but if you are able to keep WOT during gearchanges and at start, your turbo will always be spooled up on a 1/4 mile.
Especially if you use a spark cut limiter with timing retard.
The problem is when you lift off the throttle and choke the turbo.Comment
HuwSy
Umluft info
I really would not do that to your car.
PRJ is /researching/developing/making something cool that people appear to be interested in, why piss all over it?Current-2004 Impreza PPP wagon
Sold ABY-stockComment
"Haters gonna hate." :corey:
Basically there are always around 16% of people who keep whining just because they don't want to be in the same boat as the rest of 84%, basic human nature unfortunaltely.
Personally i'm really pleased with the Launch feature, I tried it on Prj-s car in drag strip and it was perfect (total 1/4th mile time was not, as it was my 2nd drag start ever). Because of some boost problems, i can't try this properly on my car, yet
BTW, when Nissan GTR came out with the launch control (more or less identical to the PRJ-s solution) even Clarckson did not bitch about it, allthough he seems to be allergic to electronics
Hi friend!
I think that it has the signal, because the clima show it with one code, and the radio turn down the volume with less speed and the cruise control needs this signal
What I don't know if it's this signal could be used to make the launch control...
When I have time I will test these signals...but now I have anothers things to do
@ all, I tested the launch control on S2 Aby avant, Rs2 setup...and when you taste it, you want it....also when you see it on live. It's adictive
I think you are right that VSS exists on 3B cars with climate, cruise and gala radios - BUT the VSS absolutely does not enter the ECU unfortunately. Adding that is probably technically possible but would be a heap of work with additional hardware and custom code to make it work.Paul Nugent
I appreciate your work though
