In theory a bad VE table can have a lean spot and till the EGO correction takes care of it it knocks.
Still be very carefull with the changes and avoid full throttle/boost runs at these high IAT till you can hear for knock and be sure about your map.
Have you checked the basic ignition timing with the timing light?
Hey Billman,
Here's the problem.recently oth of us has been running the VEMs w/o IAT working correctly
Since we forgot to upload another 2 patch files.the IAT seems to show 20-23 C deg. Constantly.
In this case,it means the ign/mat retard table was not working so after we have uploaded the
2 patch files.we found out that our VE table needs to be tuning again.the upper right table is running way leaner
than we had on stock IAT sensor.we're having some kinda detonation issue and we're sorting out the
Proper ignition table and lambda target.we're living under tropical weather in Thailand.it's hotter almost
Year which means we have less indense air and fuel quality.we have E10 E20 E85 fuel available.soon we're going to
get tuning with E85 for the better detonation resisted and performance side.the problem is we don't know how to read and understand the
Knock 0 1 2 3... Windows on the VEMs log view.how to identify the number if it's detonation or still on the safe side
For that number.I need to be stay tuned for a while until I got the better and cover all regions on VE table.
Sorry about the off topic, but I would like to ask you about the IAT problem you talk about because I have the same problem. VEMS always shows the same IAT, 23°C. What did you do to fix this?
