what does the knock 0 1 2 windows mean on VEMS?
  • Billman
    • 4129
    In theory a bad VE table can have a lean spot and till the EGO correction takes care of it it knocks.
    Still be very carefull with the changes and avoid full throttle/boost runs at these high IAT till you can hear for knock and be sure about your map.
    Have you checked the basic ignition timing with the timing light?
    Go Holset or Go RS4
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      you meant this?
      one of a few I5 from Asia.
      • Billman
        • 4129
        what exactly?
        *I can see the picture now*
        Go Holset or Go RS4
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Originally posted by Billman
          what exactly?
          It's the timing light gun for checking the basic timing.
          • Billman
            • 4129
            #20
            Yes. You must check if in Primary Trigger settings/TDC after the trigger is correct?
            Go Holset or Go RS4
            • Billman
              • 4129
              #21
              I posted it on vems forum to see what other think about the knock window graph and the coincidence with other events.
              Go Holset or Go RS4
              • popdemonic
                • Dec 2007
                • 1304
                • Country: Thailand
                #22
                Thanks Billman.you posted on vemssupport?
                • Billman
                  • 4129
                  #23
                  yes here
                  Go Holset or Go RS4
                  • EBR
                    • Jan 2009
                    • 64
                    • Country: Iceland
                    #24
                    Originally posted by popdemonic
                    Hey Billman,
                    Here's the problem.recently oth of us has been running the VEMs w/o IAT working correctly
                    Since we forgot to upload another 2 patch files.the IAT seems to show 20-23 C deg. Constantly.
                    In this case,it means the ign/mat retard table was not working so after we have uploaded the
                    2 patch files.we found out that our VE table needs to be tuning again.the upper right table is running way leaner
                    than we had on stock IAT sensor.we're having some kinda detonation issue and we're sorting out the
                    Proper ignition table and lambda target.we're living under tropical weather in Thailand.it's hotter almost
                    Year which means we have less indense air and fuel quality.we have E10 E20 E85 fuel available.soon we're going to
                    get tuning with E85 for the better detonation resisted and performance side.the problem is we don't know how to read and understand the
                    Knock 0 1 2 3... Windows on the VEMs log view.how to identify the number if it's detonation or still on the safe side
                    For that number.I need to be stay tuned for a while until I got the better and cover all regions on VE table.
                    Sorry about the off topic, but I would like to ask you about the IAT problem you talk about because I have the same problem. VEMS always shows the same IAT, 23°C. What did you do to fix this?
                    Thanks, Eiríkur
                    Audi S4 20VT 11.453@121.62
                    • KRIENG
                      • Apr 2009
                      • 68
                      • Country: Thailand
                      #25
                      yes same as me when we upgrade firmware but didn't read this link ( No. 5 )
                      sorry we must tune VE again and ignition change too.
                      I'm wrong with IAT 22-23 in one year. Thank for Pop told me.
                      I'm think how many Vems I5 wrong.
                      http://www.efiexpress.com/catalog/ar...?articles_id=6
                      • popdemonic
                        • Dec 2007
                        • 1304
                        • Country: Thailand
                        #26
                        lol,as i told you there must be a lot folks having same issue since they forget to upload those patch files.
                        • cooperquattro
                          • Jan 2011
                          • 815
                          Mine is the same..I use 1.8t mat sensor and mind is stuck at _14(I think) if g use aby sensor it sticks at 23,what is the issue
                          • Billman
                            • 4129
                            #28
                            If your VEMS was assembled for original MAT sensor then in order to fit 1.8t sensor you need to remove an SMD resistor from inside VEMS.
                            Go Holset or Go RS4
                            • cooperquattro
                              • Jan 2011
                              • 815
                              It must be configured lo run 1.8 mat as this was supplyd at the same time,might be patch file issue???
                              • Billman
                                • 4129
                                #30
                                If it was supplied with it then you most probably have wrong data.
                                Go to Vemstune menu: Input, MAT sensor curve and choose VEMS standart mat. Is almost same with the 1.8T mat in the data.
                                Go Holset or Go RS4
