DIY Mapping, I5 experience
  • diesel des
    • 3896
    #31
    Can we just use a stock knock sensor, in stock position, through amp to head phones? I got a little pre amp, but have been too lazy to try this out. But if its known to work then I will deffo do it.
    • a4kquattro
      • Feb 2005
      • 411
      yep. Its what I do...
      see here:
      http://www.efiexpress.com/catalog/ar...?articles_id=4
      Marc Swanson
      Proprietor, EFI Express
      95.5 //S6 Avant
      90' Coupe Quattro V8 4.2L twin turbo
      93' //S4
      83' UrQ
      97' F250 7.3 diesel
      • sam80quattro
        • Oct 2006
        • 1496
        is there any books or guides anyone can recommend reading for getting into mapping?? im gonna have a go at mapping my 10vt on 034 but would like to read up as much as possible before starting.. or is it a case of dive in and get on with it?
        • diesel des
          • 3896
          #34
          Eg I got something like this http://www.maplin.co.uk/low-noise-st...amp-kit-220053
          • GazzaG60
            • 4133
            megamanual.com
            • GazzaG60
              • 4133
              using a stock sensor is not using the one the engine uses. if the engine one is bad you may see lots of lovely knock on graph or hear it but does that stop the engine blowing..no
              checking condition and torque of factory sensors is handy. as is hitting one with a spanner lightly to simulate retard knock for retard. can be done at idle.
              • diesel des
                • 3896
                #37
                I must get the soldering iron out. If I tap in at the ecu, the stock knock cables are shielded right?
                • diesel des
                  • 3896
                  #38
                  I'm on vems, so not worried about confusing motronic
                  • sam80quattro
                    • Oct 2006
                    • 1496
                    Originally posted by GazzaG60
                    megamanual.com
                    • adam g
                      • Feb 2007
                      • 445
                      Originally posted by a4kquattro
                      Does this work well for you? so the laptop is used as the amplifier and thats it or do you use some sort of filtering/visual software.
                      • a4kquattro
                        • Feb 2005
                        • 411
                        it works great. and yes, the laptop becomes the amp.
                        spotting knock is easy.
                        no knock:
                        knock:
                        http://www.efiexpress.com/downloads/knock.mp3
                        Marc Swanson
                        95.5 //S6 Avant
                        93' //S4
                        83' UrQ
                        97' F250 7.3 diesel
                        • adam g
                          • Feb 2007
                          • 445
                          Defo read as much as possible first. Jumping straight in and fiddleing with things you dont understand properly melts pistons (the voice of costly experience).
                          You will probably find one of the biggest drawbacks is not having a rolling road. The open road is okay for getting it running pretty well but I think it will be difficult to map it on to get the most out of my car so will probably pay someone else for the fine tune.
                          • GazzaG60
                            • 4133
                            I prefer open road to be honest.
                            I don't drive on a rolling road. I prefer to either drive and log or be the passenger and tweak as I go.
                            ive found that air, temp and other factors such as hills and driving style affect certain parts. granted rollers allow you to set rpm etc.
                            leaning to know what is needed is prior knowledge plus experience. first mapping session I ever did burned a hole in a Subaru ported header. good job it was weak. that was on map apparently written at the time by the best Subaru tuner around. timing was so low egts went up faster than fuel prices at the moment
                            • prj
                              • Mar 2010
                              • 6308
                              Stock ECU will not retard on idle no matter how hard you hammer it. There's a MAP threshold from which knock control is activated. Just thought i'd throw this in.
                              Probably not too relevant to what you said.
                              • prj
                                • Mar 2010
                                • 6308
                                Just to be clear - is the mic JB welded on the back of the clip somewhere and the teeth of the clip used to hold it onto the engine, so the noise is transferred through the metal clip?
                                Yeah, you got it. Push the mic against the metal clip, then cover the back and everything else around it fully with JB weld or a similar "liquid metal" compound.
                                After this the mic will only pick up vibrations transmitted through the metal clip and no outside noise. Don't try to use glue for this, as glue will melt.
                                Cementing the mic to the clip is very important, otherwise it's like just putting a mic dangling in your engine bay, which is completely useless.
