Speed density Stage1+ tune
  • -ice-
    • Oct 2011
    • 173
    I can help you testing, but i don't want to send my ecu (i need it and you are far away from Germany )
    sounds like it needs more hardware modifcation than swapping the eproms?
    Bye
    • prj
      • Mar 2010
      • 6308
      Bye
      Correct.
      Buy 2nd ecu…
      Btw if you think that you can modify the tune easily, you are mistaken.
      All the high speed diag is stripped and there is lots of protection, so if you change even one byte, it won't work anymore.
      And if you can remove this you probably don't need my code
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        Does the maf less motronic have similar fuel efficiency as the maf present tunes?
        • -ice-
          • Oct 2011
          • 173
          Don't worry, i'm not interessted in analyzing or modifying your code. Also I won't search your checksums, swapped address lines or changed resistor deviders
          Ecus are even in germany very expensive. From 300 to 500€, you have to pay on ebay.
          So, this has to wait...
          Bye
          • prj
            • Mar 2010
            • 6308
            I don't think there's going to be any difference, as long as the engine is stock and the tune is made for it.
            If the engine is modified and the ECU tune not adjusted, then fuel efficiency will drop somewhat.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #21
              I see. Good stuff.
              • edge_devil
                • Jun 2009
                • 186
                Hi PRJ,
                Just asking out of curiosity, I have a standard engine...well almost...and my ECU has been socketed and I have a latch board to suit the chips I have, would this fall under the standard price, or the already tuned option...?
                I don't have a spare ECU so it would be my live ABY ECU btw...
                Ta
                • prj
                  • Mar 2010
                  • 6308
                  Originally posted by edge_devil
                  Hi PRJ,
                  Ta
                  Standard price. I never tuned your ECU.
                  • edge_devil
                    • Jun 2009
                    • 186
                    K, thx
                    • -ice-
                      • Oct 2011
                      • 173
                      Hello Prj,
                      Any news? Does it run well?
                      • Nickl23
                        • Mar 2015
                        • 13
                        Any word
                        On this tune for mostly stock cars?? I have a mostly stock car! Stock as in I have just a stock k24 turbo.. awaiting big turbo but I need a tune for now! Id love to go mafless! I actually just emailed you through your website so I hope to hear a response soon!
                        Best
                        -Nick
                        • prj
                          • Mar 2010
                          • 6308
                          A canned SD tune isn't going to work.
                          I've tested on a few cars locally and every one of them has needed adjustment, because each owner had done a little something to their car.
                          With a MAF it's not a problem, but with a MAP sensor it is.
                          Will just have to wait for the self-tuning board. That will come with base tunes for stock and other stuff.
                          • larsaskogstad
                            • May 2020
                            • 674
                            • Country: Norway
                            #28
                            Very old post, but are you still tuning Motronic and can do solution like this? Got a 3B car that would love to get rid of the MAF..
                            https://www.s2forum.com/forum/member...-3b-1991-coupe
