Hey all, im going for an 800 awhp setup and i'm stil deciding which engine management system to use on my 200 quattro. I want to use preferably maxxecu but its pricey for 1800 euro and then there is VEMS but ive heard stories about processing power or problems with mapping. Positive is its only 800 euro. Does anybody has other good engine management systems except EMS or megasquirt which can run a flex fuel sensor and detect water level in your ethanol? Im now running basic motec with different chips. So if anyone has any experience they want to share or advice im more than happy to hear it.
Which engine management system to use ?
MoTeC is very high tech, have you considered them?Last edited by cardcrash; 22 August 2016, 15:18.RS2 - Project Mental Wheels
RS2 - LHD on the road again
RS2 - reduced to component parts
RS2 Saloon replica
A4 1.8T
BMW 320d Touring M Sport Business Edition auto
sigpic -
Motec is very high priced. Over 2k easy. I can vouch for maxxecu. You wont regret!1990 2.2 20VT Audi Coupe Quattro
*Hx35/k26, MaxxECU, Wagner EM/IC *RS2 Recaro *4pot-Brembo *3" turboback *Treser *Koni/H&R
1990 Audi 200 20v Avant 2.2 20VT *7 Seater *Full electric gizmosComment
There is a lot of choice out there. It depends what you want in terms of functionality. Motec is probably the best out there, but at a big cost. But if you want to go with lots of data and telemetry then it comes into its own.
For a mid range and mid cost, MaxxECU and Link G4+ are the two options I looked at - high quality hardware and good softwar that is easy to use. In the end I bought a MaxxECU.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
Ecumaster Emu.
I think the best choise, if you dont want to spend over 1000€.
I tuned alot of this ecus and I really love it.
They also have a plug and play adapter.Comment
Plenty of people having good results with vems. No processing problems that I know of?
Sent from my LG-H955 using TapatalkComment
Hi, have you take a look at http://www.emeraldm3d.com. They have a 'plug and play' lead for the AAN/ABY loom so no cutting. http://http://www.emeraldm3d.com/ecu...i-aan-aby.html
The Emerald K6 has plenty of configurable inputs from specific sensors.
The Emerald K6+ and the a new version of software are all in development too.Comment
I was using motronic for years and then VEMS. I also mapped several cars on VEMS (and Motronic) for years now. But for some reasons, I was looking for a better I5 ECU.
So last year I read descriptions/manuals and installed the software of ALL the following ECUs to compare:
Megasquirt
EMS
EMtron
Motec M1
AEM Infinity
Syvecs S6 S8
LifeRacing F88
Halltech Elite
ECU481
MAXXECU
LINK G4
Vipec
Tatech
Autronic
ECUMASTER
Triject
KMS
DTA S80
Fueltech
After weeks and moths of comparing and doing configs for the I5 in different ECU software to get a feeling, my decision was the new Link G4 Thunder.
I had to start from scratch and also had to build a wiring connector.
After very lot of homework and calculating a configuration on the bench, the engine was starting with the first keyturn and idling fine but I still have to do a lot of mapping in the car now. I like this ECU very much but its in the 1800€ range + looms.
my first keyturn -->
I'm interested to see what the general consensus is on the Haltech series of ECUs as they are favoured by the Mighty Car Mods boys and they seem to know what they're doing (the Haltech guys)....RS2 - Project Mental Wheels
RS2 Saloon replica
A4 1.8T
sigpicComment
If you are looking for a cheaper unit - the Ecumaster EMU is very good for what it does.
More expensive - Link/Vipec.
Even more expensive - Autronic.
And by far the most expensive is Motec.
As it is possibly a race car - you need to answer questions such as Dash integration, Traction control (if allowed), E-throttle support to create proper antilag and so on. Autronic and Motec work very well together, for example the Motec dash has support for the Autronic stream protocol. So you can save a little on the ECU and if you need one of the best dashes in the world, you can easily add it later.
And most importantly - who is going to map your car? If you know who is going to be mapping it, then throw this entire thread out of the window and ask them what ECU to fit. Then fit it. This will give you the best result.
Let me put it this way - your initial question is far too vague. The answer is "the right one for the job".
If you are not planning on motorsport, maybe planning to map the car yourself then the Ecumaster ECU is cheap, works well, has great support, and is a professional product.Comment
This got me intrigued. Still after full pricing Ecumaster costs about the same as VEMS package.If you are looking for a cheaper unit - the Ecumaster EMU is very good for what it does.
If you are not planning on motorsport, maybe planning to map the car yourself then the Ecumaster ECU is cheap, works well, has great support, and is a professional product.Last edited by RichLV; 23 August 2016, 11:00.Comment
Looking at the ecu master it doesn't support 4.9lsu wideband.
Also for me I never liked the option of having an adapter for the ecu which will mean that I would have to modify the dash to fit it.
Of course this makes little sense for a race carComment
I dont like adaptors too - but I like hot glue armageddons much less
but like prj said, it all depends on your specific goals and capabilitys. Some points for me, full race functions, CAN, on board LSU4.9 Lambda , on board EGT, on board knock control
AND reliability!!!
- fortunately I dont need a tuner
[__]=oooo=[__]Comment
