Which engine management system to use ?
  • #31
    I have 2 vems ecus one on my urs4 and the other for my urq. I bought the urq ecu second hand and it has gave problems. But now vems have actually replaced the entire ecu with a brand new one for less than 200 euro. Sure it took some time and messing around but that's how things go. I would have no reservations buying another vems ecu. I find it quite easy to map to be honest and I'm no expert.
    I have also had a moronic ecu fail on me too so everything can and will brake.
    • #32
      It's funny how many VEMS guys are just like Scientologists
      • #33
        Originally posted by Error404 View Post
        As usual with these threads it's VEMS Vs everyone else
        Love your posts. Always incisive and to the point.
        Apologies to anyone else - no offence intended.
        As you were.
        • #34
          Likewise, no offence intended
          • #35
            Scientologists!!! now that's some crazy 5hit
            RS2 - Project Mental Wheels
            RS2 - LHD on the road again
            RS2 - reduced to component parts
            RS2 Saloon replica
            A4 1.8T
            BMW 320d Touring M Sport Business Edition auto
            • #36
              You wouldn't recommend one of those then!
              Audi 90 quattro (Typ 85)
              20v turbo conversion
              • #37
                Darn self correct. Motronic converts to moronic lol
                • #38
                  Don't need to be so defensive Vas, I'm not attacking VEMS and I never have. You pay your money you take your choice. Just adding my decision making process to the thread.
                  I am not being defensive. I fail to see the logic behind your 'conserns' and hence I see that you will face the same hurdles with maxxecu as you would have with vems.
                  I'm a bit out of sync with spiritual and religious matters so when it comes to scientology I fail to see the joke [emoji12] [emoji12]
                  To sum I think this forum has now about 10 threads going back and forth for aftermarket ecu and people have enough information to decide or get in touch. It's starting to get as boring as the infamous 'discussions' with Dmitri and motronic tuning [emoji23] [emoji23] . So it's for these reasons that I'm uut
                  • #39
                    Originally posted by A80Avant View Post
                    As I said. Glitches was a thing of the past back in 2010 to 2012 when upgrades in vems were constant. Even then you could run and map the car without a problem.
                    This is simply not true. fought major issues in 2015 ending in new firmware development by VEMS. And was not able to map and run the car with those glitches. Maybe you are still using 1.1.96
                    But you dont need glitches that crack your engine to be pissed after a while
                    Glitch could be simply a wrong setting or a poor sensor. Pissing around with settings??? Sorry but even the best base map you'll get needs a lot of tinkering before it runs right
                    You are funny... how many ecus did you map in the past??
                    Who said that with any aftermarket ecu you won't run into glitches? Just wait. They happen with all ecus
                    Nobody. Found some bugs in LINK after 3 days of usage - ending in new firmware by LINK. LINK developer support was brilliant.
                    But again, dont missunderstand my posts. Im not promoting or advising against something. I'm just telling my experience and my decision.
                    [__]=oooo=[__]
                    • #40
                      I dont get why people starting to fight each other about an ECU
                      [__]=oooo=[__]
                      • #41
                        Maybe it's because the ecu is in effect the cars brain, so opining that it is glitchy is like calling someone's car stupid.
                        Sent from my D5803 using Tapatalk
                        • #42
                          Only VEMS guys get fighty, hence why they are like Scientologists
                          • #43
                            good points
                            [__]=oooo=[__]
                            • #44
                              Chef
                              • #45
                                You're all wrong, twin Webers are the way forward
