adaptors question
  • tom
    • Dec 2004
    • 282
    adaptors question
    do the original Audi adapters 8A0615125A fit with porsche callippers 996.351.429.10 (996 turbo) together with 322mm A8 or optionally 345 S8 discs or need some changes??
  • topsparky
    • Oct 2005
    • 2014
    ask bry (he's the man in the no tha nose)
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
    • pastures16
      • 2058
      those are rs2 carriers they will fit the 996 with 1mm spacers
      94 s2 avant
      aoc member 1116
      • BRY
        • 3755
        on a 323mm disc.
        Or just bend the spring retainers so that they are higher in the middle to lcear the disc, try them you'll see.
        • pastures16
          • 2058
          @ bry did you get a price on those rears mate
          94 s2 avant
          aoc member 1116
          • Alistair C
            • 693
            No they won't fit.
            They'll fit the 996 c2 / c4 calipers, but the turbo calipers the next size up and have mounting holes further apart than the 130mm used on the boxster / 996 vehicles.
            I thought 996t calipers were 145mm ish between centres?
            See info on this convers ion here: http://www.s2forum.com/forum/showthread.php?t=11774
            (996t calipers are the same as early GT3 - before the GT3 had 6-pots)
            • BRY
              • 3755
              oops
              missed the turbo bit, sorry
