do the original Audi adapters 8A0615125A fit with porsche callippers 996.351.429.10 (996 turbo) together with 322mm A8 or optionally 345 S8 discs or need some changes??
adaptors question
ask bry (he's the man in the no tha nose)Originally posted by tomdo the original Audi adapters 8A0615125A fit with porsche callippers 996.351.429.10 (996 turbo) together with 322mm A8 or optionally 345 S8 discs or need some changes??
1. SHORT SHIFT KIT
2. PORSCHE CAYENNE CALIPERS
3. H & R SPRINGS
4. BILSTEIN SHOXS
5. NEW BUSHES AND HP2 STRUTS
8. fmic fitted -
Originally posted by pastures16those are rs2 carriers they will fit the 996 with 1mm spacers
on a 323mm disc.
Or just bend the spring retainers so that they are higher in the middle to lcear the disc, try them you'll see.Kingdoms are run by Kings, Dictatorships are run by Dictators.
England must be a Country. :mischeif:Comment
No they won't fit.
They'll fit the 996 c2 / c4 calipers, but the turbo calipers the next size up and have mounting holes further apart than the 130mm used on the boxster / 996 vehicles.
I thought 996t calipers were 145mm ish between centres?
See info on this convers ion here: http://www.s2forum.com/forum/showthread.php?t=11774
(996t calipers are the same as early GT3 - before the GT3 had 6-pots)Last edited by Alistair C; 11 December 2005, 22:24.Comment
