I got mine for £15+ £4p+p not bad eh? Bargain of the month.
Are these necessary for a 996 conversion ?
Is there anything special about these shims?
Are they magnetic? Made from anything special?
From what i can see, it looks like a peice of plate with two bosses on it that insert into the caliper pistons.
If it is this simple then I might be able to get a replacement designed up and made (as long as it is nothing special). Can't see it being expensive.Comment
from memory no, simple plate with two alu bosses with a philips head screw in each to hold onto the plate. Nothing special I can think ofsigpic
1992 3b S2 CoupeComment
Ok then,
BigLeeM, do you think you could get me some accurate dimensions from those shims you just bought?
I'll have a chat to a friend of mine who should be able to knock a few up.
I'll check with him first though.
DanComment
sounds promising Dan, I'll keep a look-out for progress. I might be right in saying that the plate has an adhesive backing so that the pads stick to the plates. At least mine have the remains of a sticky back on themsigpic
FAO Dpicariello/Dan
As you requested buddy
Hope these are good enough
A 119mm
B 90mm
C 50mm Centre to centre
D 21mm
E 43mm
F 17mm
G 1mm this is the thickness of the black backing plate(made of plastic)
If there is anything else that you need let me know. Hope this helps
Thank you very much,
I will speak to my mate and see if it is possible to get some of these made up.
Thanks for your help, much appreciated.
DanComment
they are anti-squeel shims and they arnt neccessary as not all 996/997 have them
