Originally posted by CliveH
View Post
314mm dics under an Avus 16"
I have a pair on the shelf, I'll try tomorrow but you do have small pistons on these and wouldn't suit most I5 master cylinders, if you want a small monoblock caliper that has decent sized pistons then you want to use the Boxster front caliper but this can only be squeezed around a disc 28mm thick maximum.Corey
01636 822288
996 rears but he has the correct set of 996's on the way as we speak, Ander's had pedal issues because he had sourced the wrong caliper's.
His new ones have been refinished to as new and will look just as good (if not better ) and will be a slightly bigger caliper than what he has at present.
Jon if you have/need a set refurbing give us a shout as we refinish all our caliper's now to as new.
OT you still need the adjustable bars?Corey
01636 822288
Originally posted by Corey View Post996 rears but he has the correct set of 996's on the way as we speak, Ander's had pedal issues because he had sourced the wrong caliper's.
Thanks for chasing them up though.sigpic
