Broken ABS ground bolt inside ABS pump
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    Guys i broke bolt of abs ground inside abs pump. Any ideas how to remove from it? Bad access and no piece outside housing. Or any ideas if can use some other spot on the ABS pump? I really dont need to loosen everything around it I want to clean contacts of the ground and thast happened
    Audi Coupe Quattro 2.3 20V
  • mike74
    • Apr 2014
    • 615
    can you not weld a nut on then unscrew the bit that's stuck?
    • Tom_
      • Oct 2007
      • 1301
      I cant reach there with welder, too little space for it. So this option is out of table What abou putting the ground from ABS to the brake cylinder? This two devices are connected with brake lines, so i think, that is conductive ??Just thought
      • GazzaG60
        • 4133
        can you remove it?
        need to drill and use and extractor
        • Tom_
          • Oct 2007
          • 1301
          I can, but i wont because of mess with the brake fluid and other stuff..I try to figure it out something more less timing difficult and less mess. Remove ABS pump is the last option
          • GazzaG60
            • 4133
            if you loosen the bolts on the back and the front is free you can lift it slightly. maybe enough to get to it with a drill. i can with mine but my lines may not be as factory. i have the same pump as it used to be a 16v mine. no evap near it though.
            • Tom_
              • Oct 2007
              • 1301
              There is one on the back and two bolts on the front...I try to loose one on the front, when i turn with the number 1 it turns as weel number 2.
              This gallery has 1 photos.
              • saltinot
                • May 2004
                • 1946
                There is a nut there and a part that consists of a cup with a stud on the end. You can buy this "cup" as a replacement part from Audi.
                • LSG
                  • May 2010
                  • 897
                  I can't really see the photos and where the earth was but so long as the unit has a earth it will be fine. I would make a new place to fix it to, check its with a meter so your happy, Job done . Good luck.
                  • Tom_
                    • Oct 2007
                    • 1301
                    saltinot That cup which is turning with the nut?
                    LSG Hows that? U can see on the first reply. THere is small hole and broken
                    There u can see the difference...
                    • GazzaG60
                      • 4133
                      those on the side with the rubber cups. the cups pull off the aroms on the bracket. the bolt with the earth on front st0ops them pulling off the bracket. if you can lift the front of the pump a little they may come loose.
                      lots of rust on them though. just noticed its a left hooker. maybe not so much play in the lines then. id go for rad out and drill presuming its a 20v q coupe
                      • Tom_
                        • Oct 2007
                        • 1301
                        Its 20V q coupe...so maybe the ventilator loosen or rad loose will be better option
                        • GazzaG60
                          • 4133
                          id pop the rad out and drill the bolt out and use and extractor.
                          the side ones jsut get new rubber fittings
                            Can you get a jubilee clip round the end of the pump and clamp a ground to it?
                            • Tom_
                              • Oct 2007
                              • 1301
                              Maybe...u mean to the oem ground spot?Or every where else on the pump body?
