Broken ABS ground bolt inside ABS pump
I cant reach there with welder, too little space for it. So this option is out of table What abou putting the ground from ABS to the brake cylinder? This two devices are connected with brake lines, so i think, that is conductive ??Just thoughtAudi Coupe Quattro 2.3 20V
if you loosen the bolts on the back and the front is free you can lift it slightly. maybe enough to get to it with a drill. i can with mine but my lines may not be as factory. i have the same pump as it used to be a 16v mine. no evap near it though.
There is one on the back and two bolts on the front...I try to loose one on the front, when i turn with the number 1 it turns as weel number 2.You do not have permission to view this gallery.
This gallery has 1 photos.Audi Coupe Quattro 2.3 20V
those on the side with the rubber cups. the cups pull off the aroms on the bracket. the bolt with the earth on front st0ops them pulling off the bracket. if you can lift the front of the pump a little they may come loose.
lots of rust on them though. just noticed its a left hooker. maybe not so much play in the lines then. id go for rad out and drill presuming its a 20v q coupe
Can you get a jubilee clip round the end of the pump and clamp a ground to it?
