porsche brakes
  • tango123
    • May 2017
    • 892
    porsche brakes
    this has probably been asked loads of times but i couldnt find a thread, will s2 16" avus alloys fit over porsche 4 pot calipers and a8 323mm discs.
    thank you in advance.
  • mac2226
    • Jun 2008
    • 1289
    Not with 323mm discs Maybe 314mm discs
    • tango123
      • May 2017
      • 892
      thanks for the advise
      • tango123
        • May 2017
        • 892
        would b5 s4 wheels fit over them?
        • gavs20v
          • Sep 2004
          • 3057
          Yes , no problem ( b5 s4 17's )
          16's won't go over the 323mm disc
          S2 Cabriolet.........
          • tango123
            • May 2017
            • 892
            cheers for the help.
            • GazzaG60
              • 4133
              fyi b5 s4 wheels fit over the porsche 993tt disc and gt2 6 pot no porbs
              • Rusty
                • 18953
                16s go over 314mm. I ran original ABY 16" Avus II for many years with these underneath.
                  Me too
                  • tango123
                    • May 2017
                    • 892
                    i've got some porsche 4 pot calipers and the 323mm, but getting the 314mm discs is an option. what car are the 314mm off?
                    thanks in advance
                    • mac2226
                      • Jun 2008
                      • 1289
                      I think a8 d2? My old setup was 314mm using Boxster s front calipers
                      • tango123
                        • May 2017
                        • 892
                        are any spacers needed or any modifying to use the 314mm? or straight bolt on under 16" avus?
                        cheers
                        • shaun5
                          • 1610
                          ive got 323mm disc's and standard Avus wheels with no spacers, not with Porsche calipers tho.
                          • mac2226
                            • Jun 2008
                            • 1289
                            cheers
                            I’m not 100% sure as I had 18” wheels.The hat height of discs sit further in chassis as well as calipers if they don’t clear oem alloy spokes? Try some wheel spacers
                            • 90quattrocoupe
                              • Nov 2003
                              • 771
                              This set up is RS2 caliper carriers, with Boxster S(996) calipers and 323 S8 rotors. The Avus 16" will fit over this combo. Here are a couple of pictures takes with a Avus 16" wheel mounted. A light is put behind the caliper, in order to show the small gap.
                              This gallery has 1 photos.
