porsche brakes
  • porsche brakes
    this has probably been asked loads of times but i couldnt find a thread, will s2 16" avus alloys fit over porsche 4 pot calipers and a8 323mm discs.
    thank you in advance.
    Not with 323mm discs Maybe 314mm discs
      thanks for the advise
        would b5 s4 wheels fit over them?
          Yes , no problem ( b5 s4 17's )
          16's won't go over the 323mm disc
          S2 Cabriolet.........
            cheers for the help.
              fyi b5 s4 wheels fit over the porsche 993tt disc and gt2 6 pot no porbs
                16s go over 314mm. I ran original ABY 16" Avus II for many years with these underneath.
                  Me too
                    i've got some porsche 4 pot calipers and the 323mm, but getting the 314mm discs is an option. what car are the 314mm off?
                    thanks in advance
                      I think a8 d2? My old setup was 314mm using Boxster s front calipers
                        are any spacers needed or any modifying to use the 314mm? or straight bolt on under 16" avus?
                        cheers
                          ive got 323mm disc's and standard Avus wheels with no spacers, not with Porsche calipers tho.
                            cheers
                            I’m not 100% sure as I had 18” wheels.The hat height of discs sit further in chassis as well as calipers if they don’t clear oem alloy spokes? Try some wheel spacers
                            • #15
                              This set up is RS2 caliper carriers, with Boxster S(996) calipers and 323 S8 rotors. The Avus 16" will fit over this combo. Here are a couple of pictures takes with a Avus 16" wheel mounted. A light is put behind the caliper, in order to show the small gap.
                              This gallery has 1 photos.
