B7 S4 rear brakes
  • B7 S4 rear brakes
    Who has used what hand brake cables with the 300mm S4 rear brake conversion on an S2 coupe ? Can’t seem to find the info in the forum.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    That’s because it’s not on hear I did months and months of research could threads all the rest. What I did so I could always use oem parts was use the cables of a b4 saloon FWD has they use the right end and can be got from most auto factors
      Let me have a look for an old for sale thread when I bought mine. They came with handbrake cables and I seem to remember they were from an Avant.
      91 Modded 3B
      14 A6 Avant Black Edition
        I used s2 avant rear cables on my s2 coupe but mines are r8 mech handbrakes and Porsche 986 rear 4 pot calipers on custom brackets discs are rear s4 300x22mm don’t know if this is same setup your running?
          I just did it on my avant. Stock kabels Do fit om that
            Sounds like some avant cables to do the job then
            This gallery has 1 photos.
            Audi UR Quattro
              Where did people get these cables? They are nla and can’t get them by part number from factors. TRW etc don’t list them
              Audi UR Quattro
                Pagid make Coupe cables, so you may find they make the Avant cables too. Mine were used items.
                91 Modded 3B
                  You might be best off working out the length you need and then spending a bit of time going through the TRW catalogue and looking for a match.
                    These were the ones I bought to use on the Brembo handbrake conversion,
                    https://www.ebay.co.uk/itm/Pagid-Rea...72.m2749.l2649
                      Quick update, I bought the cables above. They are no good for the S4 rear calipers. The ‘end’ that site in the calipers is a small metal slug and not a ball so it isn’t retained at the caliper. I will order some other cables today and see if I can get something that works
                      Audi UR Quattro
                        Struggling with handbrake cables on the S4 rear brake conversion! Maybe i need genuine cables?
                        The Pagid cables are plenty long enough in the outer body, but the inner section is too short to be able to mount in the bracket by the lever and then fit onto the caliper lever?
                        Have i completely missed the obvious here?
                        Audi UR Quattro
                          Can you shorten the outer a little? I’ve done this on motorbike cables and a car throttle cable before, you have to pull the end ferrule back, strip the plastic outer off, dremel or hacksaw through a coil of the outer (without touching the inner. Not easy!)
                          Then unwind the outer, re-instate the ferrule and your inner is now longer
                          I was also wondering if you can get a converter nipple to change the small slug into a ball end, they do these for bike cables. Or turn something up in brass and solder it on.
                            This is a great site for cable items. I've used them to make up throttle cables for reversed inlets.
                            https://www.venhill.co.uk
                            91 Modded 3B
                            • #15
                              You could slot any of these to make the end larger https://www.venhill.co.uk/cables-amp...pples.html?p=3
                              91 Modded 3B
