Today I decided to look at the NS brake calliper as the car is swerving to the right when braking. One the capper was removed from its mounting I depressed the brake pedal to force the pistons out but they never moved. Next I undid the bleed nipple and engaged the assistance of Mrs Brown with some down/up brake pedal operation. Surprisingly nothing canes out so I then removed the calliper to check the flexi hose and still nothing came out despite inserting a wire and checking for blockages. Last of all I undid the brake pipe from the outlet on the ABS unit and that gave the same result. Anyone had anything similar, maybe it’s the brake bias valve? The only other thing I’ve noticed is the brake pedal is quite hard but after a while it has freed up and the calliper starts working again but goes back to normal after leaving for a week.
NS Front Brake Not Working - ABS Issue?
Tags: None
After a good period of driving it will operate as normal like it did on the journey back from Torquay to Doncaster. I think I will start taking a look at the unit this weekend.
Can someone please tell me how to purge the ABS?Last edited by steverrquattro; 24 February 2023, 11:25.Comment
That is odd. As Mac say's could be the solenoid in the ABS unit.
I was going to suggest a collapsed fleixi pipe but you've ruled this out by the sounds of it...1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
I have a spare abs unit here if you are stuck.Nothelle S2 Avant
Urs6 plus project goneComment
First of all I gave the block on top of the ABS unit several taps with the mallet as I’d read this on another thread. I then tried pressure bleeding and when I opened the bleed nipple nothing came out but it did dribble out from around the threads. The bleed nipple was then removed and found to be blocked. When installed back in I was finally able to bleed the brake.
However when road tested the calliper on the NS was still not engaging. So it was removed once more from the carrier and the brake pedal applied. This time the piston came out but just one whereas I expected them both to come out? It was then pushed back in and the pedal applied again and the other one came out. Pushed it back in and then road tested and now working.
All I will say at the moment is that the fluid looks dirty and I’ll do another test drive tomorrow to see if it’s still working.Comment
It’s got the best service history of any car I’ve ever seen but that brake fluid is rank. Where do you get your rebuild kits from?Comment
Sometimes you have to take service history with a pinch of salt! One of my neighbours always has his car serviced every year, but refuses to have any fluids changed other than oil, his car is on an 07 plate he has had the car since new. He's thinking of selling it and claiming it's got full service history
Think I got my kits from autodoc, but you can get them from ebay as well
Front
D41719C AUTOFREN SEINSA Repair Kit, brake caliper Front Axle ➤ AUTODOC
Rear
D4845C AUTOFREN SEINSA Repair Kit, brake caliper Rear Axle ➤ AUTODOCComment
Agree. Those brakes need an overhaul.Nothelle S2 Avant
Absolutely brilliant that and very much appreciated. Also thanks to Tractor Dave for the offer of the spare ABS unit.Sometimes you have to take service history with a pinch of salt! One of my neighbours always has his car serviced every year, but refuses to have any fluids changed other than oil, his car is on an 07 plate he has had the car since new. He's thinking of selling it and claiming it's got full service history
Front
Rear
Rebuilding the brakes is a job I've never done as it's always been a case of not having the time resulting in an emergency exchange at GSF. However I fancy doing these myself and save a bit of cash as well.Comment
Not too difficult and very rewarding. Send me a pm if you get stuck. I've done quite a few now. I would recommend getting a kit with new pistons.
We did the front calipers on my lad's Skoda recently, we were fitting new pads and pistons were quite hard to push in. I looked under the dust seals and could see rust.
Got pistons and seals from Autodoc, not expensive and the job went well and he now has excellent brakes.Comment
