NS Front Brake Not Working - ABS Issue?
  • steverrquattro
    • Oct 2006
    • 787
    Today I decided to look at the NS brake calliper as the car is swerving to the right when braking. One the capper was removed from its mounting I depressed the brake pedal to force the pistons out but they never moved. Next I undid the bleed nipple and engaged the assistance of Mrs Brown with some down/up brake pedal operation. Surprisingly nothing canes out so I then removed the calliper to check the flexi hose and still nothing came out despite inserting a wire and checking for blockages. Last of all I undid the brake pipe from the outlet on the ABS unit and that gave the same result. Anyone had anything similar, maybe it’s the brake bias valve? The only other thing I’ve noticed is the brake pedal is quite hard but after a while it has freed up and the calliper starts working again but goes back to normal after leaving for a week.
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
  • mac2226
    • Jun 2008
    • 1289
    Alright steve it could be the solenoid in the abs unit as this happened to a friends s2 coupe aby
    • steverrquattro
      • Oct 2006
      • 787
      After a good period of driving it will operate as normal like it did on the journey back from Torquay to Doncaster. I think I will start taking a look at the unit this weekend.
      Can someone please tell me how to purge the ABS?
      Steve
      1990 RR 20V
      • K Simmonds
        • Dec 2007
        • 7627
        That is odd. As Mac say's could be the solenoid in the ABS unit.
        I was going to suggest a collapsed fleixi pipe but you've ruled this out by the sounds of it...
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
          • Dec 2017
          • 5987
          I have a spare abs unit here if you are stuck.
          • steverrquattro
            • Oct 2006
            • 787
            First of all I gave the block on top of the ABS unit several taps with the mallet as I’d read this on another thread. I then tried pressure bleeding and when I opened the bleed nipple nothing came out but it did dribble out from around the threads. The bleed nipple was then removed and found to be blocked. When installed back in I was finally able to bleed the brake.
            However when road tested the calliper on the NS was still not engaging. So it was removed once more from the carrier and the brake pedal applied. This time the piston came out but just one whereas I expected them both to come out? It was then pushed back in and the pedal applied again and the other one came out. Pushed it back in and then road tested and now working.
            All I will say at the moment is that the fluid looks dirty and I’ll do another test drive tomorrow to see if it’s still working.
            Steve
            1990 RR 20V
            • B5NUT
              • Sep 2021
              • 1071
              That fluid looks well passed it's best. I would also look at a rebuild kit for the callipers. My guess rust has got on the piston and that's what is causing it to stick. I would also look a rebuilding the rear at the same time.
              • steverrquattro
                • Oct 2006
                • 787
                It’s got the best service history of any car I’ve ever seen but that brake fluid is rank. Where do you get your rebuild kits from?
                Steve
                1990 RR 20V
                • B5NUT
                  • Sep 2021
                  • 1071
                  Sometimes you have to take service history with a pinch of salt! One of my neighbours always has his car serviced every year, but refuses to have any fluids changed other than oil, his car is on an 07 plate he has had the car since new. He's thinking of selling it and claiming it's got full service history
                  Think I got my kits from autodoc, but you can get them from ebay as well
                  Front
                  D41719C AUTOFREN SEINSA Repair Kit, brake caliper Front Axle ➤ AUTODOC
                  Rear
                  D4845C AUTOFREN SEINSA Repair Kit, brake caliper Rear Axle ➤ AUTODOC
                    • Dec 2017
                    • 5987
                    Agree. Those brakes need an overhaul.
                    • steverrquattro
                      • Oct 2006
                      • 787
                      Front
                      Rear
                      Absolutely brilliant that and very much appreciated. Also thanks to Tractor Dave for the offer of the spare ABS unit.
                      Rebuilding the brakes is a job I've never done as it's always been a case of not having the time resulting in an emergency exchange at GSF. However I fancy doing these myself and save a bit of cash as well.
                      Steve
                      1990 RR 20V
                        • Dec 2017
                        • 5987
                        Not too difficult and very rewarding. Send me a pm if you get stuck. I've done quite a few now. I would recommend getting a kit with new pistons.
                          We did the front calipers on my lad's Skoda recently, we were fitting new pads and pistons were quite hard to push in. I looked under the dust seals and could see rust.
                          Got pistons and seals from Autodoc, not expensive and the job went well and he now has excellent brakes.
                          • sal_s2
                            • 1288
                            AndyP has rebuilt quite a few sets of brakes for people
                            • AndyP
                              • 6049
                              Be careful ordering from Autodoc, their parts cross referencing system is crap and you'll inevitably get the wrong kit! I get all mine from Biggred.
