Well I found the reason for the leaking caliper, ordered a seal kit from Hi-Spec, and rebuilt both front calipers.
Now I'm having trouble bleeding the brakes. Apart from shearing off one of the bleed nipples
I just can't seem to get a firm pedal.
I'm using one of the kits that fits onto the bleed nipple with a non-return valve at the end of the pipe.
I got a satisfying amount of air out of the rear brakes and I had a lovely firm pedal when I'd finished doing all the calipers.. until I started the engine. Then the pedal hits the floor and the brakes are next to useless
What am I doing wrong?
I just can't seem to get a firm pedal.I'm using one of the kits that fits onto the bleed nipple with a non-return valve at the end of the pipe.
