Big, Big Reds!! 330mm GT3
This is a sticky topic.
  • -Henke-
    • Jun 2011
    • 10
    • Home: Sweden
    #31
    Thank you once again!
    /Henrik
    • Skruf
      • Feb 2012
      • 15
      Does anybody have dimensions for GT3 (429/430) caliber bracket with 330mm brake disk for RS2 ? Or where I can buy them?
        Vrs aka will20v on the forum
        • Skruf
          • Feb 2012
          • 15
          Thanks again Jamo!
          Bought the calibers from Teilecar.com with brakepads and it seems that i can get a pair of brackets from VRS. Whats the disk peole are using, are there any differences except with Porsche 965.351.045.00 / 965.351.046.00 versus 996.351.409.02 / 996.351.410.02. Which type of rotors to order ?
            Does anyone happen to know the weight of these 429/430 calipers?
              Originally posted by Skruf
              Thanks again Jamo!
              I don't know I used the Zimmerman discs as they were half the price of the Porsche OEM ones
              • Billman
                • 4129
                #37
                Are there Zimmermann for the big reds?
                Go Holset or Go RS4
                  See post earlier in thread I put all numbers up last year
                  • Billman
                    • 4129
                    #39
                    Can you please clear if these are for 5x112 or 5x130?
                    Go Holset or Go RS4
                      It's an RS2 setup do the math
                      • Billman
                        • 4129
                        #41
                        Now I can do it.
                        Q: The big red discs are 322x32mm. I see these are 330x34? They do fit on the stock RS2 big red setup with stock brackets?
                        Go Holset or Go RS4
                        • Skruf
                          • Feb 2012
                          • 15
                          OK.
                          This is the rotor we are talking:
                          http://www.ebay.de/itm/ZIMMERMANN-SP...item3a55af4eeb
                          Jamo are you using VRS adapters or some custom made ?
                            Those are the discs I'm using custom brackets. I don't have the dimension to share if this is what you really are asking
                            • Billman
                              • 4129
                              #44
                              What is the most economic disc set for stock RS2 big red setup?
                              Go Holset or Go RS4
                              • Skruf
                                • Feb 2012
                                • 15
                                I was just thinking the rotor issue and double checking which is the right for the VRS adapter because in their Ebay item it says to use 911 964 Turbo rotors.
                                But I can´t find any dimensions for that rotor to check is ~same as Zimmermann´s that I poisted
