As some of you know I am a bit of a brakeophile and have a very expensive habit of upgrading my brakes whenever I need new pads/discs (or when I get bored). Since buying the car all those years ago it has now had six brake upgrades (3 front, 3 rear)
1. I started off with the old favourite of RS2 front calipers with 314mm A8 discs. Not bad especially compared to the stock setup.
2. When it was due new front pads I then stepped up to the RS2 'big red' setup again with A8 discs(323mm this time). Better than before but still room for improvement.
3. Meanwhile at the back I upgraded to 256mm TT discs with B5 S4 calipers.
4. The RS2 'big reds' fell victim to the familiar corrosion issues and got to be so noisy I just had to upgrade to the RS6 365mm setup. No really, I had to
5. It was the rears turn to be played with again after that with the now familiar 300mm B7 S4 setup.
This gave a very well balanced braking setup which has since been used by quite a few people to good effect.
Now the reason for me mumbling on is that as the 300mm setup was becoming common and I was getting a bit bored with it so my mind started to wander. About six months of discussion and design with Jason 'the wizard' Dakin culminated in upgrade number 6...
[/rant]
Thanks for the thread man! =) I feel the same as you do over brakes. There's something erotic about big brakes.
Hehehe...
you're officially mad! Your rears are bigger than my fronts now! Good work playing with the new toys tho, I'm sure there's lots of other little projects you've got on the go that we'll find out about soon enough.
