Originally posted by A80Avant
View Post
RS2 Brake pads and discs part numbers
This is a sticky topic.
This is the disc that looks excactly like the oem drilled disc at the rear. But I'm not sure about the size of the disc to know if they can work.
http://www.type911shop.co.uk/shop/ar...26aid%3D484%26
I have used Sebring and Zimmerman rear cross drilled discs but they tend to rust fairly quickly and even crack between the holes. The Sebring were better than the Zimmerman for wear and rust. I went back to plain discs from the 944 turbo. Porsche part 951 352 041 01 - AUDI part 8AO 615 601C. I do believe the Porsche part for cross drilled is 951 352 041 91 - AUDI part 8AO 615 601D.
S
Originally posted by simesf View PostI have used Sebring and Zimmerman rear cross drilled discs but they tend to rust fairly quickly and even crack between the holes. The Sebring were better than the Zimmerman for wear and rust. I went back to plain discs from the 944 turbo. Porsche part 951 352 041 01 - AUDI part 8AO 615 601C. I do believe the Porsche part for cross drilled is 951 352 041 91 - AUDI part 8AO 615 601D.
S
I have heard that there are non drilled 322 discs but I don't know the number. I had the same problems with the salt but found the original Porsche drilled discs weathered well - it was the other makes that rusted. Even the hat didn't rust on the originals! I finished by using the RS non "floating" version as they were cheaper - around 480 euros per pair in Germany for the original Porsche parts. They have done over 30,000 kms and still fine.
I see your point.
Well I'm looking at the 993 options for front and rear. Unfortunately I haven't been able to find a good pdf with all the specs of the discs as well as their part numbers. I know the rears need to be 77mm from disc to outer hat surface but when I go to the online shops they are sold by make instead so I cannot be sure. 993 rear discs are also said to be 290/24 so they could work but I have to cross reference that before buying them. I will keep at it as I have to eventually get discs and even zimmermanns from Germany are fairly expensive now so not worth it.
Still waiting from design911 which were very helpful in regards to looking into the sizes and possible part numbers.
In the mean time i found a nice shop that had sizes and managed to find the following: (HAT size measured from inner disc surface to the face of the hat, where the wheel bolts on)
FRONT DISCS:
HAT: 77.5mm (from Audi)
Porsche part numbers:
Model:964/911 3.6l turbo 322x32
96535104500 (right) Drilled
96535104600 (left) Drilled
Model: 928 GTS 322x32
92835104501(right) NON Drilled
92835104601 (left) NON Drilled
REAR DISCS:
HAT:77mm or 73mm or 71mm
model: 928 GTS
95135204101 299/24 NON Drilled
As mentioned above, the only way to get drilled option at the rear is pay 500+euro to get the OEM sport version, or get a zimmerman/sebro equivalent sport disc
Originally posted by Mr G View PostFront little red pad part number - Porsche (Textar) is 993-351-949-00
Anyone got the Porsche parts number for the small red front pads?!
Sorry for the old bump
