996 Calipers questions
  • Rozvor
    • Feb 2009
    • 10
    • Country: Spain
    Hi
    Finally I bought the 996 calipers to fit on my S2. They have the references:
    - 996.351.425
    - 996.351.426
    And I bought the S8 323mm discs too. Now, the question
    - What bracket need to fit this kit on my S2?
    - What modifications need the bracket?
    - Any store to buy a modified bracket?
    Regards
  • europeanme
    • Oct 2005
    • 3817
    have a search through the forum....but IIRC you need the SEAT brackets but as they cost a lot more than they used to people are looking elsewhere
    there have been some different ones for sale on ebay and on this forum....
    good luck...
    • dest
      • 4287
      RS2 carriers bolt straight on dont they?
      • europeanme
        • Oct 2005
        • 3817
        not over 323mm discs AFAIK...
        • Sonic
          • Jul 2006
          • 5514
          RS2 brackets out the box IIRC or SEAT ibiza cupra R brackets machined down:
          There is also a run through here - http://www.s2forum.com/996-brake-upgrade/
          S2Forum.com Administrator
            The Seat brackets are stupid money now..i had a set at £30 odd each about 2 days before they went to £200+ each
            The RS2 brackets should be a straight fit though and a lot cheaper than the Seat ones
            • gavs20v
              • Sep 2004
              • 3057
              ive just done this conversion on the cab, rs2 carriers fit fine over the 323mm discs with no modification.
              Youll also need hoses as the s2 have different fittings to porsche calipers. Rs2 braided hoses from goodridge fit straight on
              Gav
              S2 Cabriolet.........
              • rj scotty
                • May 2006
                • 2195
                Rs2 carrier on 323mm discs are fine.
                I've ran them for a year now with one track day
                cheers
                rich
                BUT I DON'T WANT A NEW CAR!
                1995 S2 Avant, Volcano Black
                • UUUdirs2newcastle
                  • Apr 2008
                  • 655
                  Is there such a thing as 'Big Reds' for the back of my RS2? I want some of those tasty drilled rear discs for my RS2, but dunno if they need new calipers too?
                  • javispa
                    • Jul 2007
                    • 292
                    • Country: Spain
                    Con los portapinzas del RS2 encaja perfecto, pero tendras que limar un poco los canutillos donde la pastilla asienta. Si no lo haces es posible que te rocen con el disco. Cuenta que el disco de Audi es un poco mas grueso que el de Porsche. Tambien es posible que tengas que separar un poco las pinzas del portapinzas usando una arandela. Es posible que las piezas elasticas que sujetan las pastillas (por la parte externa de la pinza) te rocen con el disco. Cuenta que el disco es un milimetro mayor que el de Porsche. Los latiguillos metalicos de RS2 van perfectos. Personalmente tuve estos problema al montar mi equipo de frenos, pero se arreglaron como te cuento. Lastima que no tenga fotos del montaje, podria ilustrarlo mejor.
                    Un saludo.
                    With the RS2 carriers these calipers fit with no major problems, but you will have to skim a little bit the part where the pad gets hold. If you don't do it, it may touch the disc. Remember that this Audi disc is a little wider than the Porsche one. You may also have to insert a spacer between the bracket and the caliper to separate it a little bit. As the Audi disc's diameter is one milimeter bigger the outer pad retainer would probably touch on the disc. The RS2 goodridge metal hoses are perfect. I had these problems when fitting mine, and were sorted out easily. It's a pity that I do not have any picture. It would be easier to show.
                    Cheers.
                    Audi Coupé S2 '92 -- VW Golf 2 GTI '91 (v2) -- Renault 4 TL '84 -- Audi 100 2,3E '92 (Dad's) -- Suzuki SV 650 S '08
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      Hi mate,
                      Some pictures, price etc. from when I did the conversion
                      Sleeper S2 Avant +450
                      A6 Avant 2.7t Stage 3
                      Audi S2 Coupe RS2'ed
                      • europeanme
                        • Oct 2005
                        • 3817
                        cheers
                        rich
                        well that shows how much I know!!.... all that time waiting for a set to be made and I could of got a pair from VAG Parts....
                        • rj scotty
                          • May 2006
                          • 2195
                          I could not get a definative answer when I was preparing to fit them. Some say you need a spacer others say you do not.
                          Like I say, 1 year in now with no spacer and no problems at all
                          cheers
                          rich
                          • Rozvor
                            • Feb 2009
                            • 10
                            • Country: Spain
                            Thanks for all
                            Tomorrow I'll buy the RS2 carriers and the bolts
