boxster s caliper question
  • avants2turbo
    • Feb 2008
    • 1287
    ah, this is the set on ebay at the moment... The auction ends tomorrow doesnt it?
    • Le S2 Audi
      • Jul 2009
      • 3805
      They were on ebay - but I have also got a front set coming from the states.
      Ended up with two sets.... Such is life!!
      New S2 - S8 & RS2 -RS6 Keyrings
      • avants2turbo
        • Feb 2008
        • 1287
        any chance u can measure your calipers and give me the offset measurement of the front calipers (as per the the little picture with the yellow lines on)
        • Le S2 Audi
          • Jul 2009
          • 3805
          I'll see what I can do, but I'm not fitting them and I don't have any pads yet.. so it maybe a while before I have chance....
          • avants2turbo
            • Feb 2008
            • 1287
            you dont need to fit them, or need pads in them, just the measurement between the bolt holes and the centre of the caliper
            • gavs20v
              • Sep 2004
              • 3057
              Its approx 50mm
              Gav
              S2 Cabriolet.........
              • bambridge
                • May 2009
                • 609
                Hi Ken,
                When they arrive let me know and i will pop over with the brackets, and check there what you need
                • avants2turbo
                  • Feb 2008
                  • 1287
                  Originally posted by gavs20v
                  Its approx 50mm
                  Gav
                  how "approx" is that?
                  • gavs20v
                    • Sep 2004
                    • 3057
                    i can try and measure it more acurately tomight as its up on axle stands with no wheels or suspension on atm. Plus or minus 2mm max. It was with a measuring tape. Ill use a proper metal rule tonight
                    Gav
                    • avants2turbo
                      • Feb 2008
                      • 1287
                      Gav
                      Thanks mate, its quiet critical as the new calipers are 54mm offset
