Resonating Brake/s
  • John Reavey
    • Nov 2008
    • 40
    Resonating Brake/s
    Finally got the 996 upgrade sorted today! On my way home when everything had warmed up there was a loud resonating noise from nearside hub which I could not feel in the steering or through the brake pedal. It sounds like driving along the ribbed line on the motorway with a frequency multiplied by 10 and is very loud! Any ideas what I might have overlooked / stuffed up? When I tip the brake pedal the noise stops but returns immediately after taking my foot off the pedal.
    They all do that sir!
    When mine does it I take the pads out and copper slip the backs, its been fine for quite a while now.
    • s2driveruk
      • 12696
      no they dont John or rather not for ages. definately check they are lubed and also check that the pegs which the pads sit on are well out the way as when the disc expands they can resonate on those too
      1992 3b S2 Coupe
      • s2_wot
        • Aug 2006
        • 2178
        John,
        Could it be a knackered (or nearly knackered) bearing? big brakes will beat the last bit of life out of tired bearings very quickly.
        Shane
        Shane
        • driftin jo
          • Sep 2007
          • 2222
          backing plate touching the disk ?
          • Ross
            • Aug 2005
            • 3399
            I had this recently, backing plate needed levering clear of the disc. I've also had the same noise due to the pins touching the disc when the brakes are up to temp.
            • Knight Rider S4
              • 3541
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
              • Dpicariello
                • Mar 2006
                • 621
                Welcome to the world of 996 brakes my friend!
                Mine do it too, have since the beginning although it's a lot better now. The pins are at least 3mm clear of the disc on mine. I have tried plastilube and copper slip. I've removed the heat shilelds and checked that all the caliper pistons a free.
                I was at Lion garage in Hinckley the other week and was advised that a good hammering gets everything quiet again. I must admit that the majority of my S2 time seems to be spent on the motorway at the moment and in this weather, things tend to get a bit crusty.
                Take care bedding them in and then make full use of them (when it's safe to do so) and it might just help.
                • John Reavey
                  • Nov 2008
                  • 40
                  Thanks for the input guys, think i'll start with the pins and check the backing plate clearance.
                  If that doesn't work I'll give them a good thrashing when bedded in a little more.
                  I'll let you know how I get on over the next week or so!
                  • Colesy
                    • Feb 2009
                    • 2980
                    There is a thread discussing this here:
                    Still haven't got to the bottom of my problems yet...
                    • Alistair E
                      • 479
                      Not sure if I should be posting this here yet but I'll take the chance. The noises from my nearside front brakes have stopped. Well, for three days so far so not counting chickens yet.
                      Only things done in between having horrendously loud noises and silence were :
                      Removed wheel
                      Removed pads
                      Champhered off outside edge of pad with a file
                      Refitted everything
                      It's always been the case that there was no noise with new pads. For this reason i have always assumed that it was the piston travel that was the problem as the pads wore down. Something I noted this time was that the pads had a lip that wasn't being worn down on the outer edge. This is because the pads sit minutely too far out from the hub.
                      I can only guess that the noise was lip on the pad catching the outer edge of the disc even when the calipers backed off. Very much like the wine glass effect.
                      Might be worth a look.
                      When I change discs in the future I'll be looking for slightly bigger diameter discs.
                      • Alistair E
                        • 479
                        Quick update.
                        Well I'm now a week into a silent car. I've had a couple of minor squeaks but I believe these may be from the offside which I haven't touched yet. Can't believe I've put up with this for nine years. Even had a change of calipers along the way.
                        Hopfully this may help others with similar problems.
                        Alistair
                        • Le S2 Audi
                          • Jul 2009
                          • 3805
                          Question... Did you trim the Guide pins on the caliper?
                          When I fitted mine I got a new set of Pad dampers (these fit into the pistons on the caliper and are supposed to stop brake squeel) at a cost of over £100.00... Ouch...
                          But you also need to drive very steady for the first 500 miles, if you have put in the A8 discs, as they are 2mm (I think) thicker than the OEM porsche discs, and with the new pads, they do rub on the disc when you start...
                          HTH...
                          New S2 - S8 & RS2 -RS6 Keyrings
                          • GazzaG60
                            • 4133
                            never had a single bad noise from my 996 gt2 6 pots on 993 tt discs and ebc red stuff.
                            no trimming except for a skim off the bottom of pad due to disc/caliper/bracket combo.even ripped off the anti rattle back plates after 2 got loose.
                            • Alistair E
                              • 479
                              I didn't trim the pins but from memory I'm running a narrower disc. I seem to recall they are 314mm x 28mm.
                              The thing I did notice when inspecting the brakes was that the disc isn't central in the caliper. The gap to the pins is .8mm outer and 2.8mm inner. The pads have worn slightly unevenly and I guess this is the reason why. Need to take 1mm off the inside face of the bell.
                              I tried to stick the old dampers to the new pads unsuccessfully. The dampers are in there now but not really doing anything
