You can't remember the part number can you, I bought some early 996 rear calipers and they did not fit as the disk was too wide. The part numbers of these calipers ended 421 and 422, Probably OK for diske upto about 20mm thick but not 24mm
Part numbers are on the bruno thread as he bought the calipers brand new, they are 421, 422 IIRC the pins need grinding
correction no grinding required
