Brembo Caliper piston sizes?
    Originally posted by Le S2 Audi
    Right at home now with a coffee and calculator in hand...
    Now before I start, lets make one thing Crystal Clear... The Prices quoted here are what the stealers have quoted me TODAY 15/04/2010 and Include My 20% Discount and I have added VAT..
    I have not added anything to these prices... So if you don't like 'em - DON'T Blame Me..
    Right...
    996-351-425 & 996-351-426 Front Calipers 996 C2, C4, Boxster S...
    Piston Sizes 36 & 40mm
    40mm Piston Repair Kit... No 951.351.917.01 Cost £12.35 for Each Caliper.
    36mm Piston Repair Kit... No 951.351.917.00 Cost £12.35 for Each Caliper.
    Damper Pad.. No. 996.351.088.01 £18.80 Each & you need 2 Per Caliper.
    Pad Retaining Springs, Bolts & Clips.. No. 996.352.959.01 £20.00 This Pack Does Both Calipers.
    Pistons Are NOT available separately From Porsche...
    996-352-421 & 996-351-422 Rear Calipers...
    Piston Sizes 28 & 30mm
    30mm Piston Repair Kit... No. 951.352.917.01 Cost £8.65 for Each Caliper.
    28mm Piston Repair Kit... No 951.352.917.00 Cost £9.90 for Each Caliper.
    Damper Pads..
    30mm No. 964.352.096.00 £7.40 Each & you need 2 Per Caliper.
    28mm No. 964.352.096.01 £7.40 Each & you need 2 Per Caliper.
    Pistons Are NOT Available separately From Porsche...
    996-351-429 & 996-351-430 GT2/GT3 C4 Turbo Front Calipers...
    Piston Sizes 38 & 44mm
    44mm Piston Repair Kit... No. 928.351.917.00 Cost £12.35 for Each Caliper.
    38mm Piston Repair Kit... No. 951.351.917.00 Cost £14.65 for Each Caliper.
    Damper Pad.. No. 996.351.089.00 £18.80 Each & you need 2 Per Caliper.
    Pad Retaining Springs, Bolts & Clips.. No. 996.351.959.30 £ For got to get this one.. This Pack Does Both Calipers.
    996-352-425 & 996-351-426 Rear Calipers... These Calipers are the same size as the 996-351-425/426 but have smaller pistons and the transfer pipes & Bleed Nipples are in the opposite holes. AFAIK
    Damper Pads..
    Done
    HTH.....
    How do you get 20% porsche discount, I need pad springs pack for 429/430 and 352 421/422
    • Le S2 Audi
      • Jul 2009
      • 3805
      Errrr Dunno... They just assumed I was a trader cos I knew all the part numbers before I order anything...
      I will get you a price on the retaining kits for the 429/430's...
      New S2 - S8 & RS2 -RS6 Keyrings
        Be £40 I reckon, might try and find my local porsche dealer on the blag
        • AndyP
          • 6049
          If your in there often enough spending money, they give you discount. I get 10-15% at Audi now!
          If in doubt, ask.
          • andy10v
            • 5996
            Might as well ask, all they can say is no. If you don't ask you don't find out.
            Sold ABY-stock
            • Le S2 Audi
              • Jul 2009
              • 3805
              #21
              If in doubt, ask.
              Wish I could get that with VW... all I get is 2%
              Know where to come when I need parts for the S2...
                Look no further than S2avant for Audi parts, you can't beat the p.diddy dealer, he's the man to trust
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  #23
                  OK, now you see my problem, my mechanic tells me that my pistons are measured at 32mm and 36mm but I cannot find a Brembo caliper that fits that description. The clues as to which calipers I have remain the following: -
                  The calipers are black (with porsche logo)
                  They bolt up to a modded SEAT carrier and a 314mm A8 disc
                  I run 996 pads which fit perfectly
                  The RS2 damper pads do not fit (but cannot remember if too big or too small)
                  I wonder, could he have measured the pistons at 32mm & 36mm but Brembo actually measure the diameter of the cylinder that the piston runs in? Clutching at straws I know but I need to get this sorted.
                  Who has a set of 996's on the shelf that they can measure both pistons and cylinders for me?
                  Cheers n
                  Si
                  P.S. @Le S2 Audi: what is in a caliper repair kit? (2 seals and 2 dust caps?)
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                    The problem as I see it as a outside source is the rebuild is going by the mechanics measurements rather than the Porsche part numbers.
                    Personally I'd buy one of each ( 36 and 40mm ) and try them, if they dont work take the caliper to porsche and ask why they don't fit.
                    Also verify the part numbers of the calipers that are embossed on the underside
                    • Le S2 Audi
                      • Jul 2009
                      • 3805
                      #25
                      Cheers n
                      Si
                      Si,
                      Has he measured INSIDE the pistons? as you are exatly 4mm out on each piston?? You really need to A; get me a picture and I could tell by looking at one... B; find out exactly what your guy is measuring and with what...
                      How is the pad held in... Is it a bolt through the top of the caliper or is it a butterfly looking unit??
                      This what a 996-351-425/6 looks like...
                      What I am thinking is could they be RS2 calipers??
                      Which look like this...
                      thanks Spink... knicked his picture..
                      If they were rears they would have a dimple above the P & E...
                      HTH
                      • HPmuirt
                        S2Forum April Fool
                        • Apr 2005
                        • 3014
                        #26
                        Thanks for the pictures, mine certainly look like the standard 996's and finally after a bit of cleaning I can confirm that I have 996-351-425 & 996-351-426 front calipers, so **** knows what the mechanic measured but I am now fairly certain that I need kits for 36 & 40mm pistons (I can feel an I told you so coming from a certain mod ).
                        So now it is down to speed of delivery against price.
                        @Le S2 Audi: what quantities are actually in your quoted caliper repair kits? Is there enough to do a whole caliper? and how fast could I get hold of them?
                        Cheers n
                        Si
                        • Le S2 Audi
                          • Jul 2009
                          • 3805
                          #27
                          Si, as I listed there is enough to do a caliper in each kit...
                          So you would need 2 of each size...
                          I can't say how long until I phone them on Monday.. But I bet you they will have to order them.. I WOULD SAY IT WOULD BE A WEEK BY THE TIME I PICK EM UP AND POST 'em to you..
                          Have you seen the group buy on the DS2500 pads for these calipers, if you are refurbing them...
                          • HPmuirt
                            S2Forum April Fool
                            • Apr 2005
                            • 3014
                            #28
                            Yes I have, but annoyingly mine arrived last week from CS at their standard price
                            Cheers n
                            Si
                            • Le S2 Audi
                              • Jul 2009
                              • 3805
                              #29
                              Just to clarify my postion on the parts & prices I listed...
                              As I have just said to Si,
                              I will get them to help peeps out on here...
                              But I'm not starting to actively sell them as I would then have to make something out of it to cover my costs and shipping charges etc, and then you can end up upsetting some peeps on here...
                              Si, You're welcome by the way.. I have enjoyed doing the research...
                                Si you have me all wrong
                                I posted a link to type911 earlier they can ship out within 2 days if you are desperate for them
