Porsche crossover pipe trailing / leading
    Anybody got any tips on swapping crossover pipes on porsche calipers.
    I need to swap them around on my rear 421 / 422 calipers but can't get the nut to move for love nor money.
    Damn found the answer from :corey:
    • PaulJ
      • Jun 2008
      • 253
      At least he done something useful !
      1995 RS2 Nogaro
      1971 Lotus Elan Sprint
      1974 Lotus Elan+2S 130/5
        What do you think is the best thing to apply heat without destroying the caliper paint?
        • BRY
          • 3755
          The correct spanner and a mechanic
          • s2_wot
            • Aug 2006
            • 2178
            with the caliper in a vice or mounted on the car.
            Shane
            Shane
              Not so useful advice above
              a) Calipers were in a vice and the nuts began to show signs of spanner work
              b) Calipers are not on the car at present and cannot be mounted.
              I'll go with :corey: for a change
              • PaulJ
                • Jun 2008
                • 253
                I done the same job last night, Was a bit foxed until i noticed sides were different lengths then just swapped sides with the pipes and all was fine
                Wrapped calipers clamped in the soft jaws of a large vice and used flared nut brake spanner 10mm I think, bleed nipple is 11mm
                Try plus gas or something like that, heat will lift the paint
                Cheers PaulJ
                1995 RS2 Nogaro
                  Cheers PaulJ
                  Flared nut brake spanner? got any details?
                  • lind4hl
                    • Jul 2008
                    • 2465
                    i think he means:
                    those are Awesome!!! to release brakeline nuts with..
                      I've got a couple of those, brake line spanners, the real ones are 6 point. Cool idea though to angle grind a ring spanner
                      You could try tapping the face of the nut with a flat ended punch and hammer. Just to shock it a bit, then have a go with the spanner.
                      • lind4hl
                        • Jul 2008
                        • 2465
                        That is for us cheap bast*rds!
                          Cheers guys bought one of these http://cgi.ebay.co.uk/Draper-Brake-F...item2306a4cdb1
                          • PaulJ
                            • Jun 2008
                            • 253
                            looks like newsh has the idea, 6 sided ring spanner with a slot wide enough for the brake pipe to fit through, sykes pickavent do them, less likely to round nuts
                            hope that helps, good luck
                            1995 RS2 Nogaro
                            • chezz
                              • Apr 2007
                              • 440
                              Can you place the nut in a metal work vice and ease the caliper back and forth to work the nut free?
