Finally found a great brake catalog from ATE
This is a sticky topic.
    First good finds are sliding pin kits for front and rear caliper carriers -
    24.0101-3401.2 front (trade number 260043)
    24.0101-3601.2 rear (trade number 260044)
  • Nuvo
    • Nov 2003
    • 3825
    That is indeed a good find. One question though, what UK based supplier could we buy these items from now that we know the part numbers for the guide pin kits?
      Well hopefully any UK motor factor can get them by using ATE part numbers.
      The thing I cannot find is rear caliper repair kits - not just the piston seal and dust cap, but all the gubbins for rejuvinatng the orrible handbrake. Dunno why I cannot find these yet.
      • Audi Parts Guru
        • 1317
        Thanks for that Paul, I'm gonna make some enquiries tomorrow to see who can supply these
        S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
        • dubmeister
          • 522
          ECP stock ATE brakes.
          • s2_wot
            • Aug 2006
            • 2178
            I think you can buy the internal bits & bobs from biggred.co.uk, they sell most of their stuff through their ebay shop. I emailed them before with the part numbers for the calipers:
            "Rear single Piston, 38mm. 38 is cast into the caliper for Audi with the following part numbers 853 615 423 A & 853 615 424 A"
            To which they responded:
            "If you type 270487160915 (ebay listing number) you will find the rear kit BR203816
            Regards John / Sarah Bigg Red Ltd Tel 01905 428793 Open Mon/Fri 10.30-6.30"
            Please do double check what you're getting in that price as i did not purchase yet. They are friendly and helpful in any case. HTH
            Shane
            Shane
              Funny enough - those 'bigred' folk came up on a search and I could see lots of Girling applications so this seems like a good path - I hadn't tried to contact them yet so that is encouraging.
              • Piefke
                • Sep 2009
                • 12
                Why do you want parts for the rear Lucas - Girling calipers from ATE and not from Lucas - Girling (TRW) ?
                Piefke
                • Audi Parts Guru
                  • 1317
                  Originally posted by dubmeister
                  Well I spoke to Euro car parts head office today, and they have never sold these kits. So they are having to contact ATE direct in Germany to see if it's worth them supplying them
                  • Pete Reeve
                    • May 2007
                    • 584
                    I Can Do The Said Ate Kits For £28.80 Each But I Will Need To Order Them In
                    Quattro Corner Audi OEM Parts
                    • Audi Parts Guru
                      • 1317
                      Pete, is this price to do 1 or 2 calipers?
                        @Pete - can you source the complete rear caliper seal / refurb kits as well ?
                        I need a pair for trusty old cast iron 38mm rears... Plus a pair for cast 43mm rears (as per RR quattro)
                        I also need a pair for alloy 38mm from 2001 allroad
                        Local motor factors have not been helpful so far
                        • Pete Reeve
                          • May 2007
                          • 584
                          As it says each means each caliper
                          • Pete Reeve
                            • May 2007
                            • 584
                            I wouldn't bother with the rebuiled kit as they dont come with parts to rebuiled the hand brake and this is what fails
                            • montez
                              • May 2010
                              • 396
                              I would recommend big red, they provided me with a seal kit for my rear girling on my old 20v, seemed pretty clued up and very helpfull
                              1991 Audi S2 Coupe
