Abs Help
  • fluk3
    • Mar 2008
    • 146
    • Home: Denmark
    Abs Help
    help my abs lamp lights as soon as I start driving
    things I have done
    1 sensor changed
    all tooth rings cleanet and ok
    I have measured all sensores all signals ok
    and still the same
  • Ian Simmonds
    • Jun 2005
    • 2858
    Did you fit new plasic caps (the silly little white things)...?
    If not, try putting 4 new ones on, they are very cheap and quite crutial for gapping the sensor to the toothed ring... Even slightly out on one sensor and the Anti-Blocking-System will fail it's rotational test and put the ABS light on.
    Chased an ABS fault on our WR for 2 years... Finally spent about £2.00 on the caps and cured it in an hour...
    93 MTMS2 Avant
      never heard of or seen these caps Ian, have you got any more info - pics, part numbers etc?
      • DJones
        • Jun 2005
        • 2020
        http://cgi.ebay.co.uk/NEW-AUDI-UR-QU...item3cac9f8928
        Not sure if the link will work..
          Thanks
          I'm guess this is a UR thing? AS can't see how or where you would fit them on the B3 / B4 hubs
          • Ian Simmonds
            • Jun 2005
            • 2858
            Ah, good point... I am making the possibly somewhat flawed assumption the two share the same set-up... Sorry if this isn't the case.
            93 MTMS2 Avant
              It would make it easier to set up the dambed things up if they did
              things I have done
              1 sensor changed
              and still the same
              Check the fuse in the ABS relay under the dash
              • fluk3
                • Mar 2008
                • 146
                • Home: Denmark
                if you takes fuse under the dashboard out then the abs lamp lights constantly.
                my lights when I put the ignition on and goes out when I start the car as it should
                but when I start driving it starts to lights again
                the plastic things ? I have not seen anywhere and do not think they are for my car
                and I forgot its a S2 3B 1991
                cheers christian bogh
                  Sounds like a sensor fault maybe - distance from the toothed ring is not right on one sensor
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    Sounds like you need to get the abs ecu interogated, just like the engine ecu...there could be many faults.
                    Time to find a friendly garage me thinks.
                    Carlos.
                    • Jonas_R
                      • 3781
                      • Country: Denmark
                      A while back my ABS light came on every time I had boost on the car. I had fixed a hose with holes that went over the battery and down to the diff controller. This hose is connected to a one-way valve that insures that the diff wont see boost. Because I fixed the hose and then one-way valve was broken then the diff would see boost all the time and then the ABS would be turned off.
                      Worth checking?
                      Sleeper S2 Avant +450
                      A6 Avant 2.7t Stage 3
                      Audi S2 Coupe RS2'ed
                      • fluk3
                        • Mar 2008
                        • 146
                        • Home: Denmark
                        the abs ecu interogated ? Does anyone know where it is ??
                        distance from the toothed ring I tjækket several times but how sensitive is the sensor to the distance
                        • fluk3
                          • Mar 2008
                          • 146
                          • Home: Denmark
                          but the car is due for inspections tomorrow so I'm about to run out of time
                          • Evilgoat76
                            • Feb 2010
                            • 278
                            • Home: Canada Current: United Kingdom
                            VAG-Com will read the ABS ECU through the normal route.
                            • fluk3
                              • Mar 2008
                              • 146
                              • Home: Denmark
                              hmm are you sure?
                              is abs brakes supported with vag-com ?
